![]() | Home > Maintenance & Mods (L322) > SAT Nav |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Afraid not. Your car uses BMW electronics and the later touch screen units are based on the Ford fibre system called MOST.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8094 ![]() ![]() ![]() |
As above - totally incompatible systems.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
For the L322's with BMW infotainment all that is required is ;
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I assume that as you have a 2004 HSE, there is no existing screen. To fit the Vogue system really wouldn't be worthwhile. The Vogue screen is pretty ordinary - you're looking at a system that's close on 20 years old.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155 ![]() ![]() ![]() |
Check this site, that's what I had done to my 2004 FF, there is also a Facebook site.
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Do you havemore info on this? Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Yes it is the HSE but I suspect the origonal owner upgraded the entertainment system as I do have a phone in the centre console and a full screen but no sat nav Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Would it then be possible to use later model BMW components? Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Probably, to a point.
https://www.fullfatrr.com/forum/topic9811....w+upgrades 2011 Range Rover Vogue SE 4.4 TDV8
Relay 1 to provide a switched negative to pin 17 on the blue plug on the TV module. Relay 2 to provide a switched positive to the camera. Both relay coils connected to the reversing lights. Co-ax from the camera centre core to pin 13 on the white plug on the TV module. 2003 Range Rover Vogue TD6 |
Brain
Yes, it’s all done in the boot mate. It’s just a screen at the front.
Excellent
