![]() | Home > Technical (L322) > instrument menu button |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Trying to activate the menu button on the instrument panel , the manual says just press for a 3-5 secs but not happening.The only thing that may be stopping it working could be that a message is trying to tell me I have a trans safe failure would this interfere with normal operations. |
Instrument info button will not work, the button on the end of the stalk. Reading the manual you select it to operate from the screen menu but remote doesn’t appear on it , I have seen this work before but for the life of me it doesn’t follow from the book.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
The button on the left hand stick ( the indicator stalk) will cycle through how much fuel is remaing, mpg, miles driven etc
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I’m pretty sure you have to press one of the 2 buttons on the instrument cluster to clear it first.
Yes will not work disappeared into Ecus infos somewhere. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
I haven't got the handbook to hand but you can programme what the button shows - time, date, consumption etc. Could it be that the programming on your button has been wiped and needs to be reset?
You need to clear the warning message before any info comes up.....then take it from there.
Managed to clear the warning this pm which was Trans Failsafe Prog so there are no arrows ,but nothing to aid reset on main centre screen.pressed the button and prolonged pressed as well. |
Ill have another look but not positive as I think Ive been into that ....weird. .I am sure I have had this before. |
Nothing to aid reset on main centre screen?
Below shows the cars screen
Using this
Ah, I think I see what you mean now.
yes changed the DVD to digital , but that shouldn't interfere with the info on instrument screen? Any ideas.
