Home > Technical (L322) > instrument menu button
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Trying to activate the menu button on the instrument panel , the manual says just press for a 3-5 secs but not happening.The only thing that may be stopping it working could be that a message is trying to tell me I have a trans safe failure would this interfere with normal operations.
Post #543930 14th Feb 2020 10:02pm
dazza1983
Im confused at what you are trying to do? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #543986 15th Feb 2020 4:15pm
alfapat
Instrument info button will not work, the button on the end of the stalk. Reading the manual you select it to operate from the screen menu but remote doesn’t appear on it , I have seen this work before but for the life of me it doesn’t follow from the book.
Thanks for replying
Post #543993 15th Feb 2020 5:07pm
dazza1983
The button on the left hand stick ( the indicator stalk) will cycle through how much fuel is remaing, mpg, miles driven etc
is this wat you are reffering to? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #544003 15th Feb 2020 6:00pm
mjdronfield
I’m pretty sure you have to press one of the 2 buttons on the instrument cluster to clear it first.
One resets the trip....it’s the other button.....
From memory anyway.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #544004 15th Feb 2020 6:00pm
alfapat
Yes will not work disappeared into Ecus infos somewhere.
Post #544007 15th Feb 2020 6:10pm
Weegie
I haven't got the handbook to hand but you can programme what the button shows - time, date, consumption etc. Could it be that the programming on your button has been wiped and needs to be reset?
IIRC it is programmed via the set up menu. John
GAP iiD BT
Post #544022 15th Feb 2020 8:29pm
mjdronfield
You need to clear the warning message before any info comes up.....then take it from there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544023 15th Feb 2020 8:53pm
alfapat
Managed to clear the warning this pm which was Trans Failsafe Prog so there are no arrows ,but nothing to aid reset on main centre screen.pressed the button and prolonged pressed as well.
Post #544037 15th Feb 2020 9:51pm
alfapat
Ill have another look but not positive as I think Ive been into that ....weird. .I am sure I have had this before.
Post #544086 16th Feb 2020 1:38pm
mjdronfield
Nothing to aid reset on main centre screen?
I’m a bit lost now.
You mean reset average fuel consumption etc?
Apologies if I’m being thick.... just that the warning on instrument cluster is separate from main centre scree.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544103 16th Feb 2020 4:43pm
alfapat
Below shows the cars screen
and the book is a tad different , shown below.
, can anyone have the instructions to reset the i/stalk from an older book perhaps.
Post #544110 16th Feb 2020 5:09pm
alfapat
I’m a bit lost now.
Using this
Post #544111 16th Feb 2020 5:14pm
mjdronfield
Ah, I think I see what you mean now.
Just as an observation, looks like you have BMW firmware on there, so prob have Mk 4 DVD sat nav.
Operation should be mostly similar though. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #544115 16th Feb 2020 5:49pm
alfapat
yes changed the DVD to digital , but that shouldn't interfere with the info on instrument screen? Any ideas.
Just had a thought , I have been in the GAP IID Tool lately , mainly to sort out the Transfer box problem , I noticed I could' nt alter things in the the CCF files. I am wandering if I have disabled anything in there.
Post #544132 16th Feb 2020 7:37pm
