![]() | Home > Maintenance & Mods (L405) > L405 autobiography illuminated tread plate replacement |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Somebody has posted this, have a search |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
https://www.fullfatrr.com/forum/topic44108.html 2016 Skoda Octavia VRS Estate
| Blackbird Member Since: 22 Feb 2020 Location: York Posts: 26
Thanks guys, Not much detail on instruction but will give it a go. Cheers ๐ |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
this should help,
Great thanks Stan this provides a bit more info. I will get some new clips and have a go at the weekend ๐ |
| Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262
Just for the record. I fitted a set of illuminated tread plates to my non autobiography model a couple of weeks ago. You only need to remove the trim on the centre pillars. The front trim under dash you can get away with just pulling the end up nearest to tread plate and sliding it underneath. Same with the rear |
Great thanks fir your help much appreciated ๐ |
Hi guys. I fitted the new tread plates yesterday and they are a big improvement. Thanks for your help ๐ |
Glad to hear it went well. Theyโre a bit of a silly design having the painted part raised around the Range Rover letters . Very vulnerable to getting scratched.
Yup, the design does mean they are vulnerable to scratching. I had some sticky carpet film that is strong and trimmed it around the plates with a modellers knife. The sticky stuff doesnโt leave a residue so can change it as needed. |
