![]() | Home > Technical (L322) > Removing ball joint - at wits end |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Happy new year to you too!
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Well done!!!. Now gives me hope when I come to replace mine. Happy New Year to all. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 670 ![]() ![]() ![]() |
Had this very battle today, just came on to see if there was a better way!
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
Eugh, did this today on the passenger side
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
A job for Plus Gas vs WD40 ?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Knock/drill/smash the gubbins out of the housing, helps if you remove the back of the ball joint with a punch and some Levering/wiggling......
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1040 ![]() ![]() |
This job is much easier if you just remove the hub a couple of well placed hammer wacks and its out |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Freeway - very specialised but the best at it's job. ![]() image uploader |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
it could be! i decided on that strategy but couldnt get the fkin strut bolts out even with a 4 ft bar. since learnt that a tig welder makes an ideal way to heat bolts to crack rust siezed bits |
So the driver's side was much harder!!!!
Walkeraj101 Member Since: 25 May 2019 Location: Wirral Posts: 3 ![]() ![]() ![]() |
Hey, I've been trying for weeks to get the ball joints out of my wheel knuckle. Started with splitters and pullers which all bent and snapped. Moved to hammers, sledge hammers and chisles. Then to air hamner and then finally to jack hamner! Oblitorated the top of the ball joint and still hasnt budged a millimeter.
As I said.......
