![]() | Home > Technical (L405) > rear climate |
can someone explain why when using the rear climate controls ,the front fan speed and temperature also change..
i think i've tried all the settings Alistair...
GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70 ![]() ![]() ![]() |
I have often wondered about that Stan. First noticed it when one of the kids had a fiddle and my blowers started howling at me . I did ask the question sometime ago about why the rear temps move up and down together in unison, yet it has the 4 zone option? Apart from "is the Sync on" response which it wasn't/isn't. The rear has to be the same temp on the O/S and N/S. Kind of figured i had a gremlin and left it at that. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Are you sure its definitely 4 zone, if it is you will have a heater box in the N/S/R wing, fan, heater radiator the whole works, which works independent of the system in the front, with both sides able to do different temps. I Found this out by accident when I had a new key programmed to the KVM, the auto electrician almost had kittens when he saw it, said he'd done a few FF's but not seen one of these. I removed the ducting so he could get access and remove the module. |
Dave, i've established that if sync is off ,the temps can be different rear and front but its the fan which is a pain as I and Gary have found when the rear passenger turns the knob and the front fan does the same..
I'll try mine tomorrow and let you know |
thank you |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Do you have rear grab handles Stan? |
well i am a bit fat yes... |
to answer your strange thought provoking question Craig, yes i do have grab handles in the rear.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
I'm on the edge of my seat waiting for the big reveal of the relevance of handles |
Most intriguing |
Tried mine today Stan, the rear heater is totally seperate from the front both temp and fan speed, if I put the rear fans on full, the front stay the same. However, if I hit the synch button, everything is controlled by the front controls, the rear fan speed control is disabled. And yes it does have grab handles above the doors, but i thought they all did. |
thanks Dave..
