Home > Technical (L405) > rear climate
rear climate
can someone explain why when using the rear climate controls ,the front fan speed and temperature also change..
i'm probably missing something obvious but other than locking the rear panel is there any way the front and rear can be independent of each other.. ... - .- -.
Post #547583 19th Mar 2020 12:45pm
Is there anything on the front screen for the climate config ?
There are some sync options but not sure if they are just left/right, but maybe also front/rear ?
Post #547584 19th Mar 2020 12:48pm
i think i've tried all the settings Alistair...
further investigation shows that when sync is on, i can control both fan and temp from the front..
as soon as the fan or temp is controlled from the rear, the sync is switched off..
the temp can be independent rear and front but if the fan is adjusted from the rear it also adjusts the front ..
so how can i have independent fan for rear and front? ... - .- -.
Post #547587 19th Mar 2020 1:22pm
GB78
England 2014 Range Rover Vogue SE TDV6 Santorini Black
I have often wondered about that Stan. First noticed it when one of the kids had a fiddle and my blowers started howling at me . I did ask the question sometime ago about why the rear temps move up and down together in unison, yet it has the 4 zone option? Apart from "is the Sync on" response which it wasn't/isn't. The rear has to be the same temp on the O/S and N/S. Kind of figured i had a gremlin and left it at that.
Post #547601 19th Mar 2020 3:56pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Are you sure its definitely 4 zone, if it is you will have a heater box in the N/S/R wing, fan, heater radiator the whole works, which works independent of the system in the front, with both sides able to do different temps. I Found this out by accident when I had a new key programmed to the KVM, the auto electrician almost had kittens when he saw it, said he'd done a few FF's but not seen one of these. I removed the ducting so he could get access and remove the module.
Post #547609 19th Mar 2020 5:18pm
Dave, i've established that if sync is off ,the temps can be different rear and front but its the fan which is a pain as I and Gary have found when the rear passenger turns the knob and the front fan does the same..
i have 4 zone btw... ... - .- -.
Post #547612 19th Mar 2020 5:43pm
diesel Dave
I'll try mine tomorrow and let you know Thumbs Up
Post #547619 19th Mar 2020 7:18pm
thank you Thumbs Up ... - .- -.
Post #547627 19th Mar 2020 7:50pm
Do you have rear grab handles Stan?
Post #547665 20th Mar 2020 1:45am
well i am a bit fat yes... Embarassed
Mr. Green not sure , I'll gave a look asap.. Wink ... - .- -.
Post #547673 20th Mar 2020 8:12am
to answer your strange thought provoking question Craig, yes i do have grab handles in the rear.. ... - .- -.
Post #547677 20th Mar 2020 8:56am
I'm on the edge of my seat waiting for the big reveal of the relevance of handles Whistle
Post #547678 20th Mar 2020 8:57am
GB78
Most intriguing
Post #547679 20th Mar 2020 9:20am
diesel Dave
Tried mine today Stan, the rear heater is totally seperate from the front both temp and fan speed, if I put the rear fans on full, the front stay the same. However, if I hit the synch button, everything is controlled by the front controls, the rear fan speed control is disabled. And yes it does have grab handles above the doors, but i thought they all did. Wink
Post #547742 20th Mar 2020 6:14pm
thanks Dave..
with my sync off the rear fan will control the front fan..the temps are separate...
i wonder what i'm missing? ... - .- -.
Post #547744 20th Mar 2020 6:19pm
