Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 25 of 38 <123 ... 242526 ... 363738>
Fox889
Webbie wrote:
A bit of advice and guidance please:
So, I have just had a service on my 4.4 TDV8 and the start of an oil leak from the oil cooler has been identified. I have been quoted £967 for parts & labour for supply & fit of a new cooler Sad
Does changing the O ring cure the problem in most cases?
How long should it take to change it cost the o ring at an independent, how much should it cost?
Can anyone recommend and independent for the job Northamptonshire or Leicestershire preferred, or Cambs, Lincolnshire at a push.
Just had my oil cooler replaced with a genuine LR cooler, job took 4.5hrs, total cost from good Indy was tad over £700.
From what I've read on here, the O rings are a few pence each & 30 mins to fit.
Hope this helps. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #547780 20th Mar 2020 10:25pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Anyone got a link please for the Viton O rings please. Bow down
Post #548231 25th Mar 2020 1:13pm
Fox889
If you go back a page it's down the bottom.
https://www.fullfatrr.com/gallery/albums/u...0rings.jpg 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #548234 25th Mar 2020 1:21pm
brian1951
Yes i saw that Fox, i need a source for some. Thumbs Up
Post #548236 25th Mar 2020 1:25pm
brian1951
A part No would be a start, need to get two asap.
Post #548281 25th Mar 2020 9:14pm
GGDR
Got mine off ebay, is there a link in here?
Try trawling back through these 25 pages
. Cheers, Greg
Post #548282 25th Mar 2020 9:33pm
brian1951
Thanks Greg, tried that but no luck.
Post #548284 25th Mar 2020 9:42pm
Baltic Blue
https://rover.ebay.com/rover/0/0/0?mpre=ht...3062415589
Available in various pack sizes, 2, 5, 10 etc.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #548286 25th Mar 2020 9:56pm
brian1951
Great, thanks Mike. Thumbs Up
Post #548287 25th Mar 2020 9:59pm
GGDR
Mine were bought in 2017 which is too old for my ebay history.
Well done Mike top man Thumbs Up
. Cheers, Greg
Post #548288 25th Mar 2020 10:01pm
Fox889
I used R&M Bearings and seals'r's for some nitrile O rings for my Tiger 955, worth a look?
https://www.ebay.co.uk/itm/METRIC-NITRILE-...2749.l2649
https://www.ebay.co.uk/itm/Metric-Nitrile-...2749.l2649 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #548311 26th Mar 2020 9:35am
brian1951
O rings arrived this morning and fitted, all looking good so far, just the mess underneath to clean up now, thanks Mike for the link to the o rings. Thumbs Up
Post #548622 28th Mar 2020 10:39pm
Baltic Blue
That’s excellent service, given the country is in virtual lockdown. Thumbs Up
Post #548634 29th Mar 2020 9:19am
Talkwrench
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Big thanks to the contributors of the thread, I’ve managed to source the o rings and fit them. I also decided it would be worthwhile changing the gaskets on the oil cooler/filler considering they’re cheap and the potential headache it can cause if they leak oil into the coolant! It’s not like I’ve got anything else to do under lockdown anyway. My gaskets weren’t actually leaking but they weren’t far off, they were very flat and brittle. However it’s still leaking from somewhere. So I’ll get back under it today and see what I can find, I did clean everything the best I could so hopefully it’ll be obvious.
EDIT:-
We'll there is oil still pouring down from the bell housing, prodominetly from the left hand bank I can't see the source of it and it isn't the oil filter / cooler area or the turbo oil feed o rings I've just addressed. Anyone get any other ideas? I've checked the best I can and it doesn't seem to be the rocker cover gaskets but can't totally rule it out. Please help Embarassed Cheers, Andy
2011 Autobiography TDV8
1996 Mazda RX7 Type RZ
Post #549327 4th Apr 2020 10:35am
GGDR
Just a note re mattgage's elbow issue: looks like the same elbow connector to the sump - the one I use to drop my oil.
I've not read about this one leaking before.
Andy Talkwrench how did you get on?
So we've collected three oil leak sources right?
- o rings oil feed pipe
- o ring inside the elbow connector
- main gasket/seal for the oil cooler body
. Cheers, Greg
Post #549837 10th Apr 2020 8:48am
