![]() | Home > Maintenance & Mods (L322) > Tow hitch removal |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8030 ![]() ![]() ![]() |
Assuming it's the factory one & not modified, that one is just a pin - there should be a clip through it on the other side.
Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6 ![]() ![]() |
Can,t see any clip on the pin neither can I see a hole in the pin for a clip,the pin is quite rusty though. It might be that the previous owner never fitted the clip to the pin. Blow torch and bigger hammer required I think.It is a westfalia towbar and the hitch is also, part no,s being 329077 and 323051 |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
If you don't want that height adjustable tow bar, I'd really like it! |
Giles, when eventually get it off I will let you know as I dont want to keep it |
If there's no pin on the other side - then it's threaded
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Bit of lube on the pin, give it a tap, then tap the lever see if it frees up.
Lovely, thanks. Really need the height adjustable one for towing a sheep trailer. |
Alastair - if it is threaded I would,nt be able to turn the pin as the it hits the actual tow bar before I can get a full turn on it, the pin looks the same as your first pic but without the hole for the clip, unless its just rust covering the hole |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4339 ![]() ![]() ![]() |
Take a picture from the other side for us to take a look |
I guess it's not threaded then |
I bought a genuine LR rubber bung to go in the end of the open receiver to finish it off nicely and keep any |
DrRob - Will take some pics tomorrow and put them on here, thanks for all comments so far everybody |
Yep - once the pin is out - then the fun really starts - trying to get the hitch out of the receiver |
Jack it up with a trolley jack under the tow hitch. That might break the rust |
