Home > Maintenance & Mods (L322) > Tow hitch removal |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
Assuming it's the factory one & not modified, that one is just a pin - there should be a clip through it on the other side.
29th Mar 2020 8:15pm |
Keith13 Member Since: 04 Nov 2019 Location: Douglas Posts: 6 |
Can,t see any clip on the pin neither can I see a hole in the pin for a clip,the pin is quite rusty though. It might be that the previous owner never fitted the clip to the pin. Blow torch and bigger hammer required I think.It is a westfalia towbar and the hitch is also, part no,s being 329077 and 323051 |
29th Mar 2020 8:39pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
If you don't want that height adjustable tow bar, I'd really like it! |
29th Mar 2020 8:51pm |
Giles, when eventually get it off I will let you know as I dont want to keep it |
29th Mar 2020 9:00pm |
If there's no pin on the other side - then it's threaded
29th Mar 2020 9:18pm |
Bit of lube on the pin, give it a tap, then tap the lever see if it frees up.
29th Mar 2020 10:21pm |
Lovely, thanks. Really need the height adjustable one for towing a sheep trailer. |
30th Mar 2020 10:53am |
Alastair - if it is threaded I would,nt be able to turn the pin as the it hits the actual tow bar before I can get a full turn on it, the pin looks the same as your first pic but without the hole for the clip, unless its just rust covering the hole |
30th Mar 2020 8:16pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Take a picture from the other side for us to take a look 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Mar 2020 8:21pm |
I guess it's not threaded then
30th Mar 2020 8:22pm |
I bought a genuine LR rubber bung to go in the end of the open receiver to finish it off nicely and keep any out. Spayed some grease in there too. Hitch now in shed 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Mar 2020 8:33pm |
DrRob - Will take some pics tomorrow and put them on here, thanks for all comments so far everybody |
30th Mar 2020 8:36pm |
Yep - once the pin is out - then the fun really starts - trying to get the hitch out of the receiver
30th Mar 2020 8:37pm |
Jack it up with a trolley jack under the tow hitch. That might break the rust 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th Mar 2020 9:09pm |
