Home > Maintenance & Mods (L322) > Tow hitch removal
Keith13
Isle Of Man
Tow hitch removal
Evening everyone, not posted before, have a 2007 TDV8 Autobiography, I have trying to remove my tow hitch but I cannot work out how it is fixed to the tow bar. Its a westfalia towbar and has the drop hitch unit, it looks like there is a pin that goes through where it fixes to the actual tow bar. I,m not sure if the pin is threaded in or is just rusted solid. photo is of the same tow as fitted to mine. Any help would be appreciated
Post #548733 29th Mar 2020 7:46pm
Assuming it's the factory one & not modified, that one is just a pin - there should be a clip through it on the other side.
Remove the clip & hit with a big hammer Thumbs Up
The threaded ones had a bolt head
Post #548740 29th Mar 2020 8:15pm
Keith13
Isle Of Man
Can,t see any clip on the pin neither can I see a hole in the pin for a clip,the pin is quite rusty though. It might be that the previous owner never fitted the clip to the pin. Blow torch and bigger hammer required I think.It is a westfalia towbar and the hitch is also, part no,s being 329077 and 323051
Post #548745 29th Mar 2020 8:39pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
If you don't want that height adjustable tow bar, I'd really like it!
Post #548747 29th Mar 2020 8:51pm
Keith13
Isle Of Man
Giles, when eventually get it off I will let you know as I dont want to keep it
Post #548748 29th Mar 2020 9:00pm
If there's no pin on the other side - then it's threaded
It must be otherwise it would just fall out eventually.......
It must be a variation I've not had - and I've had 3 different ones.....
I've had this one with a pin & also with a bolt
and also this one -
So I'm guessing your's is the later, which is threaded half way
Post #548753 29th Mar 2020 9:18pm
Bit of lube on the pin, give it a tap, then tap the lever see if it frees up.
As said it’s either threaded or just a pin. If it won’t smack out then it’s threaded. Simple as that.
Getting the bar out may require a big hammer if it hasn’t been out for while!
My westfalia detachable boss needed a massive hammer after just 4 years....... Massive 5lb sledge, and a bit of a TAP..... There is nothing that can't be fixed with a hammer😜😜
Post #548765 29th Mar 2020 10:21pm
gilesharrison
Lovely, thanks. Really need the height adjustable one for towing a sheep trailer.
Post #548799 30th Mar 2020 10:53am
Keith13
Isle Of Man
Alastair - if it is threaded I would,nt be able to turn the pin as the it hits the actual tow bar before I can get a full turn on it, the pin looks the same as your first pic but without the hole for the clip, unless its just rust covering the hole
Post #548886 30th Mar 2020 8:16pm
DrRob
Take a picture from the other side for us to take a look Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548889 30th Mar 2020 8:21pm
I guess it's not threaded then Very Happy
Back to plan A - soak in WD40 for 24 hours & big hammer Thumbs Up
There are probably better things than WD, but works for me
Post #548890 30th Mar 2020 8:22pm
DrRob
I bought a genuine LR rubber bung to go in the end of the open receiver to finish it off nicely and keep any Censored out. Spayed some grease in there too. Hitch now in shed Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548892 30th Mar 2020 8:33pm
Keith13
Isle Of Man
DrRob - Will take some pics tomorrow and put them on here, thanks for all comments so far everybody Thumbs Up
Post #548893 30th Mar 2020 8:36pm
Yep - once the pin is out - then the fun really starts - trying to get the hitch out of the receiver Rolling with laughter
If the pin is corroded in, then expect the same for the hitch.
There was someone who resorted to a bottle jack between the drop plate & horizontal bar as the only way to get theirs out.....
Post #548894 30th Mar 2020 8:37pm
DrRob
Jack it up with a trolley jack under the tow hitch. That might break the rust Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #548898 30th Mar 2020 9:09pm
