![]() | Home > General > Laying Up Ideas. |
But when you drive through a puddle you are A, Driving so your brakes should be hot! & B, when you wash your car, you stick a hosepipe through the spokes of your wheel to wash them! Leave the car standing after washing it and the brake surfaces will rust and after a week or 12 without driving it and you may have some issues! ![]() ![]() ![]() |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
How about spraying the discs with WD40 or Spray Grease?
Flat spots!!! This ain’t going to last five years sir! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
I just started mine (no problem) and drove it back and forth on the drive. Being as most RRs are auto and I have a level drive I pretty much always just leave it in Park and have no trouble with sticking brakes. Geoff |
Thanks Craig. You reckon that’s over doing it? Appreciate your advice ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
Rob, started and drove mine after not touching for over 2 weeks and had no problems...no charger and no extra puff in tyres..
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 252 ![]() ![]() |
I agree stan, mines been sat for just over 3 weeks, only started to move a trailer , in park with epd applied, everything working as normal, wouldn't expect anything else. Remember:- amateurs built the ark
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Mine ran fine today after ~2.5 weeks, which is pretty much it's usual duty cycle as it normally gets used every other weekend, but was only a fairly short journey so won't have completely charged the battery.
Paul - get the ctek mxs10. Go big or go home |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
My msx10 is plugged into the Bmw. But the 405 is fine.
All ordered last night and should be with me on Thursday! Yep, I had exactly the same thinking - if buying an expensive CTEK, I thought I might as well buy the 10 amp one, so I can have as a power supply when using the IID as well. Will hopefully last a good few years. Once it arrives and I've had a play with it, will see if I want any extra quick connect leads for other cars/boats. I assume like others on here I'll probably put a quick connect on the L322. |
The CTEK MXS-10 arrived yesterday, pretty quick delivery from Amazon in the current climate.
Nice one Paul! Pictures of the 107 please! Had a few 80"s in my time and a 1949 still in the family since 1975 |
