Home > General > Laying Up Ideas.
Page 3 of 4 <1234>
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I find giving the brakes a good blow out with one of these gets rid of any moisture on the brakes. It also does a good job of removing water from behind trims and door shuts.
Post #549015 31st Mar 2020 9:45pm
Bill wrote:
So if I drive thru a puddle in my driveway I’m a bit b.....d ( techinical term )
But when you drive through a puddle you are A, Driving so your brakes should be hot! & B, when you wash your car, you stick a hosepipe through the spokes of your wheel to wash them!
Leave the car standing after washing it and the brake surfaces will rust and after a week or 12 without driving it and you may have some issues! Whistle Whistle Rolling Eyes
Post #549019 31st Mar 2020 10:04pm
DrRob
How about spraying the discs with WD40 or Spray Grease?
Any thoughts on pumping tyres up to 50psi to prevent flat spots?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #549364 4th Apr 2020 4:08pm
Flat spots!!! This ain’t going to last five years sir! Whistle Thumbs Up
Post #549365 4th Apr 2020 4:12pm
supershuttle
I just started mine (no problem) and drove it back and forth on the drive. Being as most RRs are auto and I have a level drive I pretty much always just leave it in Park and have no trouble with sticking brakes. Geoff
Post #549366 4th Apr 2020 4:16pm
DrRob
Thanks Craig. You reckon that’s over doing it? Appreciate your advice Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549367 4th Apr 2020 4:46pm
Rob, started and drove mine after not touching for over 2 weeks and had no problems...no charger and no extra puff in tyres..
mine was left in park like Geoffs...
i think many are over thinking this and with summer here the battery will be fine.. ... - .- -.
Post #549372 4th Apr 2020 5:38pm
nearlee
Wales
I agree stan, mines been sat for just over 3 weeks, only started to move a trailer , in park with epd applied, everything working as normal, wouldn't expect anything else. Remember:- amateurs built the ark
Proffesionals built the titanic
Post #549395 4th Apr 2020 8:34pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549400 4th Apr 2020 9:20pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Mine ran fine today after ~2.5 weeks, which is pretty much it's usual duty cycle as it normally gets used every other weekend, but was only a fairly short journey so won't have completely charged the battery.
All this lay up talk has got me seriously considering finally purchasing a CTEK charger (which I have admired many times!), not just for this, but to use on various other cars and boats as well, as we only have a bunch of fairly ancient and low powered 12V chargers.
Post #549402 4th Apr 2020 9:32pm
DrRob
Paul - get the ctek mxs10. Go big or go home Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549424 5th Apr 2020 9:06am
My msx10 is plugged into the Bmw. But the 405 is fine.
Put the old-new battery I bought for the 322 in the 405 yesterday. All seems fine except for a call from Lr incontrol telling me I’d disconnected the battery....... Thud There is nothing that can't be fixed with a hammer😜😜
Post #549425 5th Apr 2020 9:14am
paulbrown22
All ordered last night and should be with me on Thursday!
Yep, I had exactly the same thinking - if buying an expensive CTEK, I thought I might as well buy the 10 amp one, so I can have as a power supply when using the IID as well. Will hopefully last a good few years.
Once it arrives and I've had a play with it, will see if I want any extra quick connect leads for other cars/boats. I assume like others on here I'll probably put a quick connect on the L322.
Post #549432 5th Apr 2020 10:54am
paulbrown22
The CTEK MXS-10 arrived yesterday, pretty quick delivery from Amazon in the current climate.
Given I was working and didn't have time to wire it in to the L322, for an initial test I just used the croc clips on a boat in the garage, and it took maybe 4 hours to fully charge that and move into Float/Level 7. I then decided to put it on my Series 1 107" using the croc clips again, and give that battery a recondition cycle as well, as the 107" still uses the original generator, which isn't the best at really charging the battery properly. It was still going after 3 hours, so I left it working away overnight, but this morning happily sitting on Float/Level 7.
Wired in the provided permanent lead to my 5.0 S/C first thing this morning, and ~4 hours took that to Float/Level 7 too. For now the connector is just under the windscreen, but need to look at whether a CTEK extension would let me route it elsewhere, towards the front grill perhaps.
Need to charge a few more things now!
Post #549863 10th Apr 2020 1:24pm
DrRob
Nice one Paul! Pictures of the 107 please! Had a few 80"s in my time and a 1949 still in the family since 1975 Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549865 10th Apr 2020 1:44pm
Page 3 of 4 <1234>
