Home > Maintenance & Mods (L322) > Rear light wiring removal
Dolphinboy
Am trying to get rid of a bit of moisture in one of my rear lights (2011) and can’t get the wiring jack off? Anyone any hints?
Also what are these extrusions? Covered by a grey cap - a vent of some sort or a buffer against the bulwark?
Post #549463 5th Apr 2020 4:47pm
The light wiring should be squeeze the top and bottom together James...
The other parts are breathers Thumbs Up
Post #549474 5th Apr 2020 6:07pm
Dolphinboy
Thanks Craig. Needed a bloody gripper to get it out. Thought I could get the bulbs out too but it's completely sealed so I presume if a Bulb had gone, it's a whole new light unit? Shocked
I take it the breathers do not allow water escape ? I have bit of water (tea spoon)in the bottom so presume I will have to drill to get it out?
Post #549482 5th Apr 2020 6:59pm
Spray the plug area with wd40 and then try and press each clip in in turn whilst prising the clip up.I find using the blade of a screwdriver works well.
Airing cupboard for a few days to evaporate the water.
Post #549486 5th Apr 2020 7:27pm
Dolphinboy
Thanks guys. Got it off in the end and now drying out inside. I Take it that it's a sealed unit and no incursion can b made into the insides (to change a bulb, dry it out etc)
Post #549507 5th Apr 2020 11:01pm
There isn't any bulbs in it James! They are all LED sir Thumbs Up
Post #549509 6th Apr 2020 12:09am
Dolphinboy
Thanks Craig. So LEDs can’t ever go wrong then .... Whistle Laughing
Post #549516 6th Apr 2020 9:49am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Yes, LED's do go wrong as proven by my SL. Both rear lights are LED and they look really crap, when some have died. I managed to buy a set of rears which were perfect and had them changed, even though my originals had enough LED's to pass an MOT. There is a minimum percentage for an MOT pass. I can't remember what the percentage was.
I sold the originals to a car dealer, as they were MOT legal, just aesthetically crap. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #549519 6th Apr 2020 10:30am
DrRob
Thread resurrection Thumbs Up
Rear side light has failed on near side.
On a MY2011 are they a sealed unit so can’t swap out bulbs?
Any pointers welcomed Bow down 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #603103 7th Aug 2021 2:39pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Just purchased a drivers side rear led light unit …see link below. Is very good finish identical to original LR one apart from no LR Logo.
https://www.ebay.co.uk/itm/184856129753
Delivery was fast . 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #603104 7th Aug 2021 3:05pm
DrRob
Thanks Bob. Mine is grey inside not black. They went black for 2012.
Got a Genuine one coming off ebay for just over £200 👍 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #603114 7th Aug 2021 5:16pm
