![]() | Home > Maintenance & Mods (L322) > Rear light wiring removal |
The light wiring should be squeeze the top and bottom together James...
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Thanks Craig. Needed a bloody gripper to get it out. Thought I could get the bulbs out too but it's completely sealed so I presume if a Bulb had gone, it's a whole new light unit? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Spray the plug area with wd40 and then try and press each clip in in turn whilst prising the clip up.I find using the blade of a screwdriver works well.
Thanks guys. Got it off in the end and now drying out inside. I Take it that it's a sealed unit and no incursion can b made into the insides (to change a bulb, dry it out etc) |
There isn't any bulbs in it James! They are all LED sir |
Thanks Craig. So LEDs can’t ever go wrong then .... |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Yes, LED's do go wrong as proven by my SL. Both rear lights are LED and they look really crap, when some have died. I managed to buy a set of rears which were perfect and had them changed, even though my originals had enough LED's to pass an MOT. There is a minimum percentage for an MOT pass. I can't remember what the percentage was.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Thread resurrection |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Just purchased a drivers side rear led light unit …see link below. Is very good finish identical to original LR one apart from no LR Logo.
Thanks Bob. Mine is grey inside not black. They went black for 2012.
