I actually just did mine a short while ago 4.4 SDV8. Its a plastic integrated sump and filter, transfer oil, transmission oil (life guard 8 ZF) and front and rear diff oil. I used a large syringe to replace the fluid.
Sorry that is all the pictures I have. Selfishly I got so in the zone when doing it that I forgot to take any pictures other than these! even though I actually intended on making a sticky post to show others how to do it...
Under trays off, sump drain out with 10mm Allen key, take off all sump bolts, drop the pan, replace, re-fill to until oil comes out of the overflow, then start her up, cycle through D,R,N,P leave in park with the engine running, and then continue filling again until oil flows out of the over flow. I then left mine over flowing for a further 5 liters to flush out the torque converter and used a standard oil catch can to catch the over flow. its a really easy job with a ramp.
All in it cost me about £500 to do all oils, diffs, transfer, and transmission.
