![]() | Home > Maintenance & Mods (L322) > Plastic sill removal. |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351
Post a picture of your modified trim before you fit it |
Dynax wax sprayed inside both sills via holes underneath. You can see it dripping out of the lower joint where there are small holes in the seam joints. Taped the vertical holes where the covers clips into with masking tape to avoid spray out! 1 tin did both sides.
Not Scrivets. Plastic rivets are different ANR2224 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 238
Part number for the 2 scrivits that are at the rear into the wheel arch liner is DYQ100230. |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
https://www.comdir.co.uk/scrivets-flush-head-type.html 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
I like them. Better than the original prise out ones They come in 8mm too Cheers Weegie 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
All done. I prefer the Freelander 2 trims cut to fit. They cover the lip a fraction more and also look more OEM. I couldn't get them to "join" the trailing edge ones due to the lip issue. I've smeared the small 2" area of exposed lip with clear waxoyl.
| sumshiftyguy Member Since: 13 Mar 2020 Location: London Posts: 36
I managed to treat both sides over the weekend. Thankfully not much rust, only some light surface patches. I treated with Kurust and then followed Matt's video with Hammerite and Waxoyl.
Kev - any luck with a picture of your mod? I'm intrigued 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
Forgot to mention this earlier, but, when I cleaned my sills last week with the plastic trim off, I saw evidence of some sort of wax dribbling out of one of the grommets [same as in one of Dr Robs photo's] can one assume then that JLR treated the inner sills with waxoyl or similar from new?
Yes, they would have been treated at the factory. I’ve just topped it up |
| Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 147
Hi All!
| fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 322
Nice looking Supercharged Rangie! ---------------------------------------
