![]() | Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Have you changed the battery for a new, correct specification one? (You've said it's a LR one, how old is it?)
| Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88
I'm not actually sure how old it is. I'm. Hoping it's the battery. I'll get some figures tomorrow and I'll post them up.
S
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
I got a gearbox overheat message several times. Swapping out the fluid stopped it coming back. There is nothing that can't be fixed with a hammerππ
I've got the 4.4 tdv8. It's not the overheat message I'm getting. Just says gearbox fault. It's there as soon as car starts up. Followed by special programmes off. As I said car is spot on. Goes through the gears perfect, sports box is great, paddle shift is spot on. That's why I'm thinking battery. |
Forgot to mention, after about 2-3 weeks, battery goes to around 50% charged. Car still starts OK and everything works apart from the above gearbox message |
R
No worries.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
You had the fault codes read ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
No fault codes came up. |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
There should be a date stamp on top of one of the battery posts, you'll need to crank your neck in at an angle to see but this may help. Not all batteries are date stamped but I believe pukka one's are. Sounds very much like a battery scenario to me sir. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Yeh I'm thinking the same. Just away to check voltage with engine off, then running, then under load. See what I get. |
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
I've had the gearbox fault message on 3 of 4 of my Range Rovers over the years, all turned out to be a weak battery, hope yours is the same. |
OK so tester showed. 12.6 car off, 14.7 running and 14.6 under load. Lights on, heated seats and heater blower full on.
| All times are GMT |
