Home > Technical (L322) > L322 2010 4.4 tdv8 gearbox fault
Page 1 of 3 123>
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
For a few months now, been getting the gearbox fault message and special programmes off. Car runs great, gearbox perfect. Any suggestions. In previous Post, I've asked about battery, thinking it could be the problem.
Post #552649 4th May 2020 5:12pm
rjff
Have you changed the battery for a new, correct specification one? (You've said it's a LR one, how old is it?)
You've asked about this on other threads and members have suggested a new one. To add my 2d worth, check the voltage at rest on the car, with it turned off, start the car and check what happens to the volage. Let us know the figures and then there may be some more help. Cheers
Richard
Gap IIDBT
Post #552667 4th May 2020 6:32pm
Shawser1203
I'm not actually sure how old it is. I'm. Hoping it's the battery. I'll get some figures tomorrow and I'll post them up.
Cheers for the reply.
Post #552672 4th May 2020 7:22pm
rjff
S
With your reply I assume you have multimeter to measure. You can also use the centre info screen to get the battery voltage at any time you wish.
I think it's the same for you, assuming yours is a 3.6.
With the centre screen on the home, touch the white bar at the top, in the centre for a slow count of five,.
then push the navigation button in for a cont of five.
You should get a numeric keypad
Hit 753 then enter and then choose values (right hand list, second down?)
Voltage should come up.
If I'm wrong on the 3.6, would one of our more sensible members correct me? Cheers
Richard
Gap IIDBT
Post #552681 4th May 2020 8:20pm
I got a gearbox overheat message several times. Swapping out the fluid stopped it coming back. There is nothing that can't be fixed with a hammer😜😜
Post #552682 4th May 2020 8:26pm
Shawser1203
I've got the 4.4 tdv8. It's not the overheat message I'm getting. Just says gearbox fault. It's there as soon as car starts up. Followed by special programmes off. As I said car is spot on. Goes through the gears perfect, sports box is great, paddle shift is spot on. That's why I'm thinking battery.
Post #552690 4th May 2020 9:09pm
Shawser1203
Forgot to mention, after about 2-3 weeks, battery goes to around 50% charged. Car still starts OK and everything works apart from the above gearbox message
Post #552691 4th May 2020 9:13pm
rjff
R
Let's see the voltages tomorrow and then fokls on here can have a clearer idea to assist. Thumbs Up Cheers
Richard
Gap IIDBT
Post #552695 4th May 2020 9:38pm
Shawser1203
No worries.
πŸ‘πŸ‘
Post #552696 4th May 2020 9:39pm
DrRob
You had the fault codes read ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #552700 4th May 2020 9:45pm
Shawser1203
No fault codes came up.
Post #552701 4th May 2020 9:48pm
Fox889
There should be a date stamp on top of one of the battery posts, you'll need to crank your neck in at an angle to see but this may help. Not all batteries are date stamped but I believe pukka one's are. Sounds very much like a battery scenario to me sir. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #552719 5th May 2020 8:33am
Shawser1203
Yeh I'm thinking the same. Just away to check voltage with engine off, then running, then under load. See what I get.
Post #552729 5th May 2020 9:37am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I've had the gearbox fault message on 3 of 4 of my Range Rovers over the years, all turned out to be a weak battery, hope yours is the same.
Post #552730 5th May 2020 9:46am
Shawser1203
OK so tester showed. 12.6 car off, 14.7 running and 14.6 under load. Lights on, heated seats and heater blower full on.
I'm. Hoping it's battery aswell. Seems to be a common problem.
Post #552737 5th May 2020 10:03am
Page 1 of 3 123>
