![]() | Home > Technical (L322) > Fitting a voltmeter into the dash |
| bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88
I put a cheap fleabay monitor in the tray ahead of the gear lever on my 2003. The rubber and plastic is ~1.2mm thick and there is just empty space under the tray so easily cut with a craft knife.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Who needs a clock..!
| TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198
Can you help me out here? I cannot find where the instructions on removing a 2011 clock panel are in Wiki or anywhere else on the forum. Sorry if my searching skills are not to snuff! 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
The clock panel is removed by tugging firmly at each end toward you but only, once the side wood trim panels have been also tugged towards, the door to give clearance, there is a screw in the foot well on each side wood panel but it can be left in situ, merely swivel the side trims downward once tugged free, then tug out the top switch panel first then the lower clock panel.. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
Had mine out at the weekend. As said, the side panels just pull off but, in mine, 2008, there were four screws that had to be removed. Two for the HVAC panel and two for the clock panel. They are quite obvious. There are two plastic lugs on the clock panel which go up under the HVAC panel and, to avoid damaging them, remove the HVAC panel first. With the screws removed the panels just pull out from their clips. PS. Unless I removed more screws than needed. Which wouldn't be a first. 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Many thanks all |
| All times are GMT |
