Home > Technical (L322) > 4.2 SC lean codes
Page 2 of 12 <123 ... 101112>
mgrover
yeah atm am just trying to fix petrol
Post #552906 6th May 2020 12:27pm
Danwilderspin
If you want to buy a sensor remember I’m here Laughing Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #552973 6th May 2020 10:24pm
Danwilderspin
Also Haylands - I was always under the impression that if they ran lean the engines ran hotter and that too caused vsr? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #552977 6th May 2020 11:00pm
mgrover
the bitch is currently leaking ACE fluid haha, so ama try some power steering additive to see if thatll stop it and if not looks like am forking out 300 for pipes and who knows how much headache haha
Post #553056 7th May 2020 2:38pm
VSR from too rich because the dry LPG gives no lube to the valves, the more there is the more the problem, and as you say a week mixture will mean hotter EGT and take out the poor little valve seats... they get it all ways..!!
If they run lean they tend to run lumpy and you know something is up, if they run rich they usually feel ok so the inexperienced will leave it because they think it runs OK, I worked for a company some years ago designing installations and the most common thing they did when servicing and repairing other peoples installs was tune them properly because they were running rich...!
Thumbs Up Pete
Post #553058 7th May 2020 2:46pm
May I suggest that you repair the leak properly and not use an additive that will attack all the rubber in the system and make it swell, hopefully stemming the leak for now but rotting the whole system in the long run...!!! Thumbs Up Pete
Post #553059 7th May 2020 2:49pm
mgrover
oh definitely its gonna be redone, the pipes are on there last legs.
Post #553063 7th May 2020 3:22pm
Danwilderspin
How are you getting on? I meant to say to you do you have an iid tool to reset the engine adaptions? That would make a big difference - I reset mine it runs okish for about 20 miles then I guess once it’s learned it’s silky smooth Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553358 10th May 2020 6:00pm
mgrover
Nah not at the moment, am waiting for ace pipes first. then ill change over sensors. then yeah reset adaptations
Post #553359 10th May 2020 6:01pm
Danwilderspin
Ace pipes? It will make a big difference the adaption especially if it ran crap on gas and then you had the valves done - definitely recommend it and getting an iid tool - if you look on here you can often pick up a classic for £120 or less the you just pay £25 ownership transfer and it can do all the adaptions etc Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553361 10th May 2020 6:26pm
mgrover
yeah there the pipes that supply the oil to the fancy anti roll bars.
and what? ive been looking at the £400 ones, would the classic ones work?
Post #553382 10th May 2020 8:44pm
Danwilderspin
Classic works fine for adaptions and 90% of other things including updates - only thing is it’s all on the cluster (certainly on the l322) or a wired laptop - is double check the are good with l320 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553384 10th May 2020 8:55pm
mgrover
ill see if i can find one of em, am proper tempted to full the trigger on one. i do have a question when you reset adaptations do the long term fuel trims go back to zero or do they just stay what they are till they start updating again?
because if i use the battery disconnect method the light goes off for about 30-40 miles and my mpg is rising, then the light comes back on, and my mpg suffers. am guessing at that point its learned the engine
Post #553385 10th May 2020 8:57pm
Danwilderspin
They reset to 0 - what are your trims like then? Can you see ? That is one thing the classic can’t show fuel trims - only bt I believe Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553386 10th May 2020 9:02pm
mgrover
the issue is there different in different parts of the rev range. at idle they are 5% ish lean, but at 1.5k rpm they are like 20% lean. thats long term anyways. other parts of the rev range they are fine, at around 3k they are very lean as well. if i keep the car constantly revving at 3k rpm it'll throw a reduced engine mode but won't actually throw any codes.
Post #553387 10th May 2020 9:04pm
