![]() | Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3267 ![]() ![]() ![]() |
It would appear that you need to have the dpf cleaned off the car. In UK, for example, my daughter had a local independent, who had the equipment, clean the dpf from her car. IIRC they had the car overnight.
Interesting. Terraclean France show a franchise in Limoges. John
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Thanks chaps
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Need to know the error codes.
Update;
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3829 ![]() ![]() ![]() |
I have been monitoring my DPF soot levels for several years now.
Cheers buddy
Ok....story so far;
Forgot to mention I was monitoring the exhaust temperatures, they never went above 365’
Correct . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4337 ![]() ![]() ![]() |
My understanding is it doesn’t just fill then empty. It does all sets of weird things to keep it low depending on a range of factors.
The more you monitor the live value readings, the more you see it going up and down doing passive regens well before you reach the 17.5- 18g active regen threshold. Soot levels can drop quite dramatically with temps in the 350c range.,
It will do a maintenance burn, if enough fuel, and driven to meet parameters.
Anyone got a low mileage 5.0l for sale?
