![]() | Home > Technical (L322) > OS/R central locking fault |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Perhaps card off and check the mechanism and all connectors and wires. No corrosion or weak spots/breaks. There's a post on here about a cable failing in the sleeve between door and body, but I can't remember if it was a lock or window fault. Try also powering the lock from a correct voltage supply. May tell you if the lock's OK and wiring/supply needs further works.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Body Control Unit (BCU). Situated under the Pax seat. Need to remove and check/replace. Also brings about heavy steering! |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
My n/s was hit and miss. I bought a replacement from Gentlemen of salvage for £19 thinking it was worth a try. All fixed and took more effort getting the door card off than anything else. 2011 4.4tdv8 Vogue
Myblackt5 Member Since: 27 Aug 2018 Location: Cornwall Posts: 12 ![]() ![]() |
When I lock and unlock the doors I can hear the actuator doing its thing.
Mine always sounded like it was working but it was too weak. It unlocked no problem if you locked by hand but rarely did it itself. On the central switch it would work more often but too hit an miss. 2011 4.4tdv8 Vogue
It's difficult to test, having to disconnect the battery. |
For the sake of £20 for a salvage item I would change it out. Mine moved but not enough to lock. 2011 4.4tdv8 Vogue
You make a good point, and they do have 1 for sale at the moment. |
The part arrived on Monday. Fitted it and it all works again.
Thanks for letting us know |
Thank you for your help. |
was it BCU or actuator? |
Actuator |
Good news.. 2011 4.4tdv8 Vogue
