Home > Technical (L322) > OS/R central locking fault
Myblackt5
Hello all,
I have had a search for this problem but cant find anything in here that matches my exact issue.
I have a 2004 L322 the offside rear door has decided that it wont unlock on the fob, or the button on the dashboard.
I can unlock it by pulling the handle on the inside.
When I lock it with the fob or button it will lock. Then wont unlock .
Any ideas?
I assume I've got to pull the door card off but what fron there?
Thanks in advance.
Post #555479 27th May 2020 10:27am
rjff
Perhaps card off and check the mechanism and all connectors and wires. No corrosion or weak spots/breaks. There's a post on here about a cable failing in the sleeve between door and body, but I can't remember if it was a lock or window fault. Try also powering the lock from a correct voltage supply. May tell you if the lock's OK and wiring/supply needs further works.
Hope this helps. Cheers
Richard
Gap IIDBT
Post #555651 28th May 2020 3:17pm
Dolphinboy
Body Control Unit (BCU). Situated under the Pax seat. Need to remove and check/replace. Also brings about heavy steering! Shocked
brand new BCU Part Number YWC000923
Post #555698 28th May 2020 5:34pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
My n/s was hit and miss. I bought a replacement from Gentlemen of salvage for £19 thinking it was worth a try. All fixed and took more effort getting the door card off than anything else. 2011 4.4tdv8 Vogue
Baltic Blue
Post #555709 28th May 2020 7:06pm
Myblackt5
When I lock and unlock the doors I can hear the actuator doing its thing.
I've had the door card off. I can't see anything obvious. Feels like its moving ok.
Currently scratching my head.
Post #555927 30th May 2020 6:05pm
Gazcw
Mine always sounded like it was working but it was too weak. It unlocked no problem if you locked by hand but rarely did it itself. On the central switch it would work more often but too hit an miss. 2011 4.4tdv8 Vogue
Baltic Blue
Post #555959 30th May 2020 11:22pm
Myblackt5
It's difficult to test, having to disconnect the battery.
Post #556329 3rd Jun 2020 9:59am
Gazcw
For the sake of £20 for a salvage item I would change it out. Mine moved but not enough to lock. 2011 4.4tdv8 Vogue
Baltic Blue
Post #556343 3rd Jun 2020 11:57am
Myblackt5
You make a good point, and they do have 1 for sale at the moment.
Post #556344 3rd Jun 2020 12:04pm
Myblackt5
The part arrived on Monday. Fitted it and it all works again.
Thank you for your assistance, saved me so much time and money.
Post #557237 10th Jun 2020 8:31pm
rjff
Thanks for letting us know Thumbs Up Cheers
Richard
Gap IIDBT
Post #557250 10th Jun 2020 10:33pm
Myblackt5
Thank you for your help.
Post #557252 10th Jun 2020 10:34pm
Dolphinboy
was it BCU or actuator?
Post #557253 10th Jun 2020 11:02pm
Myblackt5
Actuator
Post #557256 10th Jun 2020 11:20pm
Gazcw
Good news.. 2011 4.4tdv8 Vogue
Baltic Blue
Post #557259 10th Jun 2020 11:57pm
