![]() | Home > Technical (L322) > Flickering Xenon light |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
HI - I posted a while ago about one of my lights flickering and then going out. Turn off and on again and it's all sorted for a while but keeps doing it now. After your helpful advice to narrow it down today I washed the beast and decided whilst in there to swap just the bulbs over to see where the problem was.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I had the same thing on a 2007. Thankfuly it was still under warranty as the repair required the replacement of both headlamps.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
ashley, i changed mine to 6000k from these peeps
Thanks Hoppy - Fairly certain it's just the bulb as the problem followed to the other side when I swapped them over.
if you are changing temperatures then you change both, if you are just replacing the faulty one then just replace that one...mine are my old ones so they are used but perfectly ok... ... - .- -.
Right - Thanks fellas - And your offer of help Scarey - I struck whilst the proverbial was still hot and bought the 6000K ones from your ebay seller mate.!
you want be disappointed with these bulbs ashley, i actually brought a second set as spares... ... - .- -.
