Home > Technical (L322) > Flickering Xenon light
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
HI - I posted a while ago about one of my lights flickering and then going out. Turn off and on again and it's all sorted for a while but keeps doing it now. After your helpful advice to narrow it down today I washed the beast and decided whilst in there to swap just the bulbs over to see where the problem was.
Sure enough the other light now flickers. I hope I can assume then it's the bulb that needs replacing.
Any one got any suggestions for replacement xenon bulb. Are dealers the best option.? (are they Loads a money)
Should I replace both to ensure the same "colour"...
What temp bulb should I go for. I prefer the slightly bluer light.
any advice greatly welcome. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #55749 20th Mar 2011 8:53pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I had the same thing on a 2007. Thankfuly it was still under warranty as the repair required the replacement of both headlamps.
I was told it was the ballast resistor that had failed/ was failing but landrover don't sell them seperately (even though they only bolt on).
You could maybe find a broken headlamp and take the resistor off it.
One of the more technical bods on here (like daveo) may well be able to offer more help/ a better solution. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #55752 20th Mar 2011 8:58pm
ashley, i changed mine to 6000k from these peeps
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
i've found these bulbs slightly brighter and more bluey [got a thread re these somewhere]
edit..found it http://www.fullfatrr.com/forum/topic4882.html
i now have a couple of original philips 4300k bulbs that are surplus ..if you want one i can do you one for £16 delivered.. ... - .- -.
Post #55753 20th Mar 2011 8:58pm
comports
Thanks Hoppy - Fairly certain it's just the bulb as the problem followed to the other side when I swapped them over.
Blimey Stan - That was quick.! Many Thanks for your offer. Should I replace both at the same time or does it not matter really? Would actually quite like the bluey tint but will let you know tomorrow if that's ok. (Aren't you selling them a bit cheap when a replacement bulb is around the £80 mark..? - Not that I want you to charge me more Whistle ) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #55757 20th Mar 2011 9:05pm
if you are changing temperatures then you change both, if you are just replacing the faulty one then just replace that one...mine are my old ones so they are used but perfectly ok... ... - .- -.
Post #55759 20th Mar 2011 9:08pm
comports
Right - Thanks fellas - And your offer of help Scarey - I struck whilst the proverbial was still hot and bought the 6000K ones from your ebay seller mate.!
Just need to source the correct LED's for indicators and side lights and I'm done..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #55761 20th Mar 2011 9:15pm
you want be disappointed with these bulbs ashley, i actually brought a second set as spares... ... - .- -.
Post #55763 20th Mar 2011 9:23pm
