![]() | Home > My Range Rover > 2004 Range Rover Vogue in Tonga Green |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Hope you enjoy yours as much as I’m enjoying mine - eventually 😉 L322 TDV8 4.4 - current
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
@chris RRv
ChrisRRV Member Since: 30 Jun 2020 Location: Belfast Posts: 104 ![]() ![]() ![]() |
Some pics finally
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
Looks lovely to me. Fitting the android is a bit of a faff because of the need to run a extension cable from the rear up to the dash. You can test the unit first before removing all the trim by connecting it up in the boot.
Thanks mate |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 37 ![]() ![]() |
Car looks great. You just can't beat a green Range Rover in my opinion! |
100% agree.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You say in your first thread it has hardon kardon logic 7... that would signify either a later car or an AB car? Was this a mistake? I ask as this will make fitting an aftermarket or BMW head unit Much more tricky, if not nigh on impossible as that would make the audio Jag based!?! |
Just going by the door cards on the car it says Harmon Kardon Logic 7
So it would appear not to be a mistake? What does your head deck look like? A MOST bus system? Ie touchscreen? If so then it’s not a BMW system but a Ford/Jag system sir... And I believe MUCH harder to replace!
Mines touchscreen, same as this
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
From that information, you have a MY 2005 with MOST optics. Note well Craig's comments. It is not easy/possible to replace. John
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Photo of the inside of the rear left cubby would let us determine for sure.
Ill get that image today |
