|  | Home > Maintenance & Mods (L322) > rear wipe problem L322 |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263      | Quote "as I am planning to advertise the old girl for sale"
|  14th Jul 2020 6:02pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | That explains the drivers door switch pack and bcm packing up a few weeks back then!!!
|  14th Jul 2020 6:14pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Have you tried slamming the boot with the wiper switches on? See if it jumps? | ||
|  14th Jul 2020 6:32pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | Not tried that, I did try flicking switch on and off and trying to move wiper arm, but it didnt start moving. Does the motor earth through the tailgate? Is that why you suggest slamming it?
|  14th Jul 2020 6:48pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Needs a new motor...., as you prob know, the water feed pipe goes through it and when it gets leaky, the motor seizes. Next thing will be rusty water leaking down the inside of the tailgate. That’s what my TD6 did....
|  14th Jul 2020 7:49pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | How come the washer pumps not working though? Surely a dead wiper motor wouldnt stop the washer jet squirting? | ||
|  14th Jul 2020 8:12pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | You mean it’s stopped running the pump? I think what tends to happen is that the water path gets blocked and the water either doesn’t come out or it squirts inside the motor and tailgate.
|  14th Jul 2020 9:23pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | Yes, you are right, it can only break once!! As for the washer, i can't hear a pump running, so I thought maybe the 2 faults were linked. But with intact fuses its just weird. I will check for power feed first, it might be the column switch at fault.
|  14th Jul 2020 9:30pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Search function should help if you need any strip down help.
|  14th Jul 2020 9:36pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | Thats a brilliant suggestion, it should as you say wipe when in reverse if fronts are turned on. I will give it a go in the morning. | ||
|  14th Jul 2020 9:47pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | The washer pump is in the front passenger corner  | ||
|  14th Jul 2020 9:54pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | along with the front washer pump, uses same water bottle?
|  14th Jul 2020 10:00pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | It can if the pipe is blocked, then the water has flowed into the wiper motor and then both the washer & wiper motors have burnt out? | ||
|  14th Jul 2020 11:18pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | OK, I suppose its possible, I will take a look at it later on today when I get back home.
|  15th Jul 2020 6:33am |
| Posting Rules
