![]() | Home > Maintenance & Mods (L322) > rear wipe problem L322 |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Quote "as I am planning to advertise the old girl for sale"
billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12 ![]() ![]() ![]() |
That explains the drivers door switch pack and bcm packing up a few weeks back then!!!
Have you tried slamming the boot with the wiper switches on? See if it jumps? |
Not tried that, I did try flicking switch on and off and trying to move wiper arm, but it didnt start moving. Does the motor earth through the tailgate? Is that why you suggest slamming it?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Needs a new motor...., as you prob know, the water feed pipe goes through it and when it gets leaky, the motor seizes. Next thing will be rusty water leaking down the inside of the tailgate. That’s what my TD6 did....
How come the washer pumps not working though? Surely a dead wiper motor wouldnt stop the washer jet squirting? |
You mean it’s stopped running the pump? I think what tends to happen is that the water path gets blocked and the water either doesn’t come out or it squirts inside the motor and tailgate.
Yes, you are right, it can only break once!! As for the washer, i can't hear a pump running, so I thought maybe the 2 faults were linked. But with intact fuses its just weird. I will check for power feed first, it might be the column switch at fault.
Search function should help if you need any strip down help.
Thats a brilliant suggestion, it should as you say wipe when in reverse if fronts are turned on. I will give it a go in the morning. |
The washer pump is in the front passenger corner |
along with the front washer pump, uses same water bottle?
It can if the pipe is blocked, then the water has flowed into the wiper motor and then both the washer & wiper motors have burnt out? |
OK, I suppose its possible, I will take a look at it later on today when I get back home.
