Home > Maintenance & Mods (L322) > DRL wiring |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
side light feed [positive] means the drl switch will switch off the drls when side lights come on,
10th Jul 2020 6:14pm |
WB Member Since: 26 May 2016 Location: London Posts: 301 |
Thank you Stan, that's great.
10th Jul 2020 8:26pm |
not sure about the ignition feed from the headlight wiring..from memory i think i might have looked for one and not found anything hence the fuse box feed..
10th Jul 2020 9:02pm |
Thanks much appreciated. |
10th Jul 2020 10:30pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 73 |
Have a look at the pictures from my install of LED DRLs around headlights to see where to source ig.
12th Jul 2020 2:13am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
B is Black Bl is Blue Br is Brown If there are two letters like B/R this would signify Black/Red (usually a Black wire with a Red tracer line through it...) If your looking for an ignition live then they are never going to be Black or Brown as they are always an "E" (earth) Have a google search sir, there are plenty of guides available |
12th Jul 2020 12:32pm |
Many thanks, really appreciate the info. I've googled it and while I've found various guides for various DRLs and controllers and installs for the wire splices mainly for the RRS I haven't found one that matches this type of DRL and my desired functionality of DRL on with ignition and off with side/headlights on.
14th Jul 2020 6:01pm |
I got hold of a good quality UK made switch and spent the last few hours taking the car apart (ehy on earth does the bumper need to come off to take out a headlamp!!!)
24th Jul 2020 8:44pm |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
Thanks Stan
1st Mar 2021 11:06am |
you're welcome.. ... - .- -.
1st Mar 2021 11:45am |
