![]() | Home > Maintenance & Mods (L322) > Early L322 steering wheel gear paddle retro fit! Amazing! |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
The L322 Paddleshift kit is appearing in this month's issue of LRO Magazine (available on the newsstands from the 5th August) has it featured in a section on "new stuff" plus there will be a full installation and review in one of the next couple of issues.
FrankN Member Since: 11 Feb 2017 Location: Vellmar, near Kassel, middle Germany Posts: 101 ![]() ![]() ![]() |
very cool , good job , my Paddleshifts are runing |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Great kit indeed! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1029 ![]() ![]() |
I use mine all the time now miss it when driving the wifes D3 as I have to go back to command shift with the stick.....doh |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Hi all - mine seem to have developed and intermittent fault. They just randomly work or don’t work. The always light up etc but sometimes when I pull a paddle nothing happens other times it does... any ideas? Current stable:
I would be checking your connection especially the earth connection under the centre console. Where did you pick up your power feed and how did you connect it ? Please dont say chock blocks |
Power and ground off cigar lighter feed spliced and soldered iirc the power I used the provided doubler thing Current stable:
That rules that out. Have you pulled the little unit under the air bag to make sure it's not shorting on anything |
No but it lights up etc with the lights sonos say that rules that out?
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Dan,
I was concerned so I wrapped the little circuit board in tape before I fitted it. |
Hi Dan - We have had one where the microswitch that is in the 3D printed block that bolts to the gear selector moves slightly backwards. Check that switch is pressing in properly when D is selected. A touch of superglue might be required to keep the microswitch in the right place in the block (but don't glue the switch itself!)
^^^Now that's customer service! |
