![]() | Home > Technical (L322) > Adaptive Dynamics Fault light |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Right being driver's side if sat in car I assume? |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
If it is RHD. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Cheers Paul - and my nuclear option repair, necessary because five or maybe more soldering repairs told me the cable had to go - is here: https://www.fullfatrr.com/forum/topic54413.html ...and I might add has been absolutely faultless. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
| EK Member Since: 09 Aug 2020 Location: Scotland Posts: 7
First, I would just like to say thanks for all the information I have learned from this site and wish I had the knowledge to contribute. Maybe one day, but for now I'm a noob.
Will have a look at my repair, very easy with a few bits off ebay:
I'm reading it now Greg. Looks like an excellent and inexpensive job you have made of it. Do you think that will be my issue looking at the wires in the pics I provided?
yes and a further look at your pics i can see a new revised wire has been spliced in. However, following the wire from the damper, there are two crimps. Undo all the tape around the original loom wire after the crimps. You may find a break here.
Going to give it a go shortly. Might be a bit of a bodge until the parts you listed turn up in the mail.
No joy I'm afraid. I checked along the length of both cables as best I could.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I’ve read a few posts about those failing, but the wiring doesn’t have to turn with the strut like the front ones, so not as common.
| paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358
I know we're in COVID times, but if there's no obvious damage then the quickest way to at least narrow down which of the 4 corners is your problem would be to get the fault codes read, whether at a garage or someone local with an IID or other suitable tool. Presumably to just read the fault codes a much cheaper code reader would suffice, and still very handy to have if you don't want/have a full on (expensive) IID type tool. |
| neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79
I had the adaptive dynamics fault appear on the dash, read it with diagnostics.
All fixed now by a local garage.
I’ve popped my cherry on this! Bling it went! IID out. Right front (drivers). Wire had parted from clearly a previous solder job. Turret off, wires stripped and soldered. Cleared fault. Sorted |
