Home > Technical (L405) > Upgrade speakers
Page 3 of 4 <1234>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So I have the car and starting to upgrade the speakers. The one in the front consoles, the cover just popped off, so that one is done.
I can't seen to pop the covers for the one's in the rear/boot. Any tips from anyone else that has done it? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #564810 17th Aug 2020 11:36am
notanrdx
United States 2017 Range Rover TDV6 Fuji White
Have never done it. Here is a pic from the WM (pre 2018).
Good luck.
Post #564831 17th Aug 2020 3:18pm
The above pic shows how they come off sir Thumbs Up
Post #564859 17th Aug 2020 11:50pm
luxmoggy
I managed to break 2 of my trim tools but they are off and the speakers replaced...
This weekend I am aiming todo the door speakers... SDV8 AB MY 2020
Post #564923 18th Aug 2020 4:51pm
notanrdx
Well better the trim tools then one of the grills I guess. Thumbs Up
Door speakers are straight forward, just watch the powerfuluk videos for removing the door cards. Getting to the tweeters on the front doors requires removing the plastic trim that wraps around the doors, but that just pops off, no hidden surprises.
Post #564924 18th Aug 2020 5:00pm
luxmoggy
Front doors done today. I had ordered the wrong sub and rear door upgrades they should be here Monday so next weekend.
Must get back to the dash cam... SDV8 AB MY 2020
Post #565192 22nd Aug 2020 4:11pm
luxmoggy
Rear doors done today. Just the sub to go... which needs me to remove the spare wheel so I can practice with the wheel hoist...
then the amp but that needs me to run power cables.
I can already hear a difference... I think it was worth it... SDV8 AB MY 2020
Post #565467 25th Aug 2020 4:35pm
notanrdx
luxmoggy, take a look at my posting re. amp swap. Its no longer a plug and play operation.
Post #565471 25th Aug 2020 4:43pm
luxmoggy
I saw that... I might try and see... but that is a winter job... I need to finish the dashcam and to wire the android screen for the rear seats... in October we have a 2 week school holiday and we are going away in the car and they are the important bits... SDV8 AB MY 2020
Post #565474 25th Aug 2020 5:23pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’m trying to find the subwoofer in mine. There’s very little info on the L405 on the net or YouTube. 🤷‍♂️
Post #710809 2nd Feb 2025 8:59am
Under the drivers seat Richie, built into the floor so you’ll need to remove the seat and then all will become obvious sir… Thumbs Up
Post #711009 4th Feb 2025 10:36am
Richie N
Thanks Craig. 👍
If it’s working would I feel it through the seat?
Post #711019 4th Feb 2025 12:36pm
Which sound system do you have? Have you tried turning the sub woofer up & down to check it? Not just the bass! The sub woofer up/down in the menu?
I have the biggest system in mine and you bet you can feel it! The lower systems, it’s not quite as noticeable…
JLR have used the chassis as a sub box essentially so you don’t just feel it through the drivers seat… Thumbs Up
Post #711046 4th Feb 2025 5:42pm
Richie N
Hi Craig,
I’ve got the 825w system.
Yes, I have played with the settings for the sub. I couldn’t tell whether it was working or not!!
Post #711064 4th Feb 2025 8:54pm
My amp tripped out somehow just the other day! I needed to reset it and all was good again… Thumbs Up
Post #711127 5th Feb 2025 3:44pm
Page 3 of 4 <1234>
