![]() | Home > Technical (L322) > DPF red - visit dealer |
Ianclark1275 Member Since: 11 Apr 2020 Location: York Posts: 67 ![]() ![]() ![]() |
Thanks for the info Dolphinboy
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
Personally the remaps worry me. The system itself as standard is full of idiosyncrasies and variation; I find having it set as vanilla as possible helps - also what are you looking to get out of a re-map - a bit of extra acceleration?
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
i was struggling with RP mode for like 4-5 weeks - everyting started with ECU remap ... came back to original software last week so far so good
Evening all
Intake side checked for leaks and none found |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
glad you got it sorted but... ouch! too late I know but quite steep that. had mine done at a place that had a flash machine and it was £250 all in . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 16th Oct 2020 9:53pm. Edited 1 time in total |
perhaps that includes the top-side investigations? Cheers, Greg
The actual clean was £330, the other cost was cutting it out and refitting etc.. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Did you have the turbo drain mod done as that was the cause of the blockage allegedly? BMW i3 Electric Car
i read the detail regards the oil drain in the invoice when i got home so im not sure i will call them and ask when i get a minute and let you all know Thanks IC |
