Home > Technical (L322) > DPF red - visit dealer
Dolphinboy
ref the cruise control initiating a restricted Power (RP) - It will do this (exactly as mine did) when there is a slight demand for power (for instance going up a slight incline - mine did this repeatedly at exactly the same spot on the M4 just as it started to go uphill) it will trigger an RP. This will most likely mean you have an air leak somewhere (mine was inlet manifold) and the ECU tries to protect the engine as boost or air mix not perfect.
Good news that yours is regenning again but it seems to be sooting up quite fast which would seem to reinforce our theory that you have a leak .....
Post #565732 27th Aug 2020 10:41pm
Ianclark1275
Thanks for the info Dolphinboy
Agreed, it’s kind of looking that way
It went up from 0.1 ( in theory) to about 15 quite quickly say 40mins then it slowed down until 18.9, which I suspect is based on the pressure differential and that it had a “quick clean” out which left some soot behind following the reset (it was told it had a new dpf)
When I’m parking or shunting about and floor it then lift off You can hear the turbo whooshing, like from a dump valve or something....
It’s had a remap (allegedly) and possibly this affects the boost pressure maybe ?
I need to drive another L322 to see if it’s just standard !
I knew I shouldn’t have cleaned it before setting off lol
Censored it down in Nairn currently
Post #565740 28th Aug 2020 7:18am
Range Rover L322
Personally the remaps worry me. The system itself as standard is full of idiosyncrasies and variation; I find having it set as vanilla as possible helps - also what are you looking to get out of a re-map - a bit of extra acceleration?
I would re-set the ECU to normal so you have a slightly more definable starting point and to eliminate that as a cause. There is then a list of other problems you can work through in order of importance/likelyhood and cost...
Good luck
Post #565805 28th Aug 2020 7:37pm
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
i was struggling with RP mode for like 4-5 weeks - everyting started with ECU remap ... came back to original software last week so far so good
https://www.fullfatrr.com/forum/topic56184.html
Post #565916 30th Aug 2020 8:43pm
Ianclark1275
Evening all
Update
I have the RR back and all fixed
Yay
Took it to JAS Land Rover near York
Very helpful and great to deal with
DPF was partially blocked with ash, which was due to a small amount of oil getting into the exhaust Via turbo oil drain on LH side apparently
Solution was to Replace £3k or clean £895 I opted for clean
It’s has to be a good process and dpf was cut out and sent away
Sleeve kit fitted and new sensors
Megaflush gearbox
Investigate cruise control issue ( worn tyres in end )
New indicator in wing
£1300
Got I back today and all good
Post #570085 16th Oct 2020 9:37pm
Ianclark1275
Intake side checked for leaks and none found
Post #570087 16th Oct 2020 9:40pm
GGDR
Quote:
clean £895
glad you got it sorted but... ouch!
too late I know but quite steep that.
had mine done at a place that had a flash machine and it was £250 all in
. Cheers, Greg
Post #570088 16th Oct 2020 9:45pm
GGDR
perhaps that includes the top-side investigations? Cheers, Greg
Post #570089 16th Oct 2020 9:47pm
Ianclark1275
GGDR wrote:
Quote:
clean £895
The actual clean was £330, the other cost was cutting it out and refitting etc..
Post #570092 16th Oct 2020 10:49pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Did you have the turbo drain mod done as that was the cause of the blockage allegedly? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #570109 17th Oct 2020 9:55am
Ianclark1275
i read the detail regards the oil drain in the invoice when i got home so im not sure
i will call them and ask when i get a minute and let you all know
Thanks
IC
Post #570258 18th Oct 2020 8:58pm
