Home > Technical (L322) > Battery's
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Unlucky Laughing EFB also works with start/stop if that's the reason why an AGM is required?
Only car in our family with start/stop is my daughter's Honda Jazz and the start/stop hardly ever works, cuts in. She doesn't mind as the car has cheaper road tax because of it.
Post #566550 7th Sep 2020 9:29pm
TheJohnnyH
United Kingdom 2010 Range Rover Vogue TDV8 Bournville
Pretty sure my Range doesn’t have start stop function :s
Post #566553 7th Sep 2020 9:44pm
Bloke
Then you don't need an AGM battery. I checked the Yuassa site and it also said my 2009 requires an AGM battery. It doesn't. Only those fitted with stop/start do. They're just trying to upsell a more expensive battery which is bad form and another reason I don't buy Yuassa batteries.
Post #566596 8th Sep 2020 11:08am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
This isn't strictly true. I have two L322 4.4TdV8's (glutton for it!), neither of which was fitted with an AGM battery when we bought them (although the correct LR part is AGM). Both have since been fitted with AGM, now it might be a finer point, but previously neither of them would run the auxilary heater for more than 30 sec or so before it cut out. Since fitting AGM, both function as they should. I should add that in all other respects the cars were fine on the previous battery, although they needed topping up charge wise if only doing short journeys few a week or so (not now required). These are simply my experiences. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #566597 8th Sep 2020 11:18am
Bloke
That's a fair point, thanks for sharing. It does go to show then that you get what you pay for and with that in mind when it comes time to replace my own FF battery from the lead acid fitted, I think I would go for an EFB as they supply more bang for the buck.
https://batteryworld.varta-automotive.com/...-do-i-need
Post #566599 8th Sep 2020 11:29am
TheJohnnyH
Th
anks all. Fitted a new Bosch agm battery today. Interestingly, Euro Car Parts advertise them at over £500...! I didn’t pay that. However, when fitting I found this. Where does it go?
Post #566638 8th Sep 2020 6:02pm
Brian Considine
If the plug has yellow wires attached to it probably the explosive charge activation (via the airbags) that disconnects the battery in the event of an accident. 2003 Range Rover Vogue TD6
Post #566680 8th Sep 2020 11:46pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
this is virtually identical to my experiences on my 2010 tdv8 which was fitted with AGM new.
the car needed a new battery and i went the cheap non-AGM route. all was fine except in cold times when the aux heater was used a few times and then followed by short journeys the car would sense 'low battery' and refuse to run the aux heater. AGM battery fitted and all was well. non-AGM battery still working fine in another role.
it may be the case that if you don't have (or use) the aux heater, or if you don't do short journeys in winter after aux heater use, that non-AGM battery will be fine
Post #567504 19th Sep 2020 8:40pm
Pestle
United Kingdom 2009 Range Rover Vogue SE TDV8 Java Black
RobWheatley wrote:
The 020 does fit, just fitted one to my TDV8, just had to move the big fuse from the side of the terminal to the top.
Probably a bit long ago now, but I don't suppose you have any info as to how you did this please?
Post #605040 28th Aug 2021 1:49pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Disappointingly my battery only holds 12.1v when I have had it on the ctek overnight. Could be the reason my FBH doesn't fire. Car starts absolutely fine but 12.1v is on the edge of failing I recckon.
Anyone used one of these?
https://www.tayna.co.uk/car-batteries/yuasa/ybx9019/
I fitted a Yuasa in my wife's 06 Boxster and it has been excellent (replaced a Bosch S4)
Thanks
Post #620243 16th Jan 2022 8:49pm
mjdronfield
Some info here…
https://www.fullfatrr.com/forum/topic62166.html
Previous cars :
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #620254 16th Jan 2022 10:41pm
Goldstar
On further investigation the Gap tool; looks like it shows conflicting info. In the top left hand corner of the main screen it was showing 12.1 but in live values it was 12.6 and 91% charge which is clearly fine. Only ever got to 14.1 with the engine running but I'm inclined to leave it be for now (Varta G14 less than a year old) and see what happens.
Post #620266 17th Jan 2022 10:01am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I recently spoke to LR on this subject AGM / NON AGM i was told all 2010 - 2012 models 3.6 & 4.4 should be fitted with a 019 AGM battery even though they do not have start / stop they even re-called early 2010 models to replace the battery with a AGM one. i was informed this is due to the smart charging system and in cold weather it can take a toll on a normal battery type. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #620269 17th Jan 2022 10:17am
Bloke
Thanks
Yes, went on holiday in September (3 weeks) and on return the battery was FUBAR. Replaced with that exact battery and it rocks. Mine is 2009 and doesn't need coding or have any of that smart charge pish the later +2010 models have. Fit and forget. Also a great price from Tayna.
https://www.yuasa.co.uk/ybx9019.html
Post #649826 4th Dec 2022 3:31pm
