Home > Technical (L322) > Whilst i was in there!
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
The other night I broke down engine stopped dead with what turned out to be a fairly major fuel leak from the sensor at the far end of the main fuel rail under the inlet manifold. we are in the process of fixing that, replacing all the glow plugs (as they are accessible now) but my real question is and has probably been covered to death, but what are peoples take on EGR valve (Leave well alone, Keep & Clean or Get rid?) I got rid of it on my Discovery 2 and that appears to be complicated compared to the unit on the RR so feel free to have your 2p worth....
Cheers
Post #567617 21st Sep 2020 3:06pm
DrRob
Ebay blanking kit for the Td6. Job done. Loads have done it. Unfortunately my 4.4 TDV8 is not blank compatible Big Cry
Oh, and get the gearbox oil changed to prolong longevity Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567618 21st Sep 2020 3:20pm
mjdronfield
I got a kit to remove it when I had a TD6. Never caused any issues doing so.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #567620 21st Sep 2020 3:27pm
best Β£30 i spent....engine ran smoother and a slight increase in mpg.. ... - .- -.
Post #567621 21st Sep 2020 3:29pm
Baltic Blue
Plus oil stays cleaner longer. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #567622 21st Sep 2020 3:36pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
bought a blanking kit when I had one, the valves are some state when you take them off. Dead easy to do too. I managed it without setting it on fire..
Post #567623 21st Sep 2020 3:50pm
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Did mine on my tdv8 it looks complicated but once you start it’s pretty straight forward but well worth it and no lights on dash πŸ‘πŸ‘
Post #567638 21st Sep 2020 7:09pm
Discofish
Thanks for the replies, looks pretty obvious which option so as per normal I'm dipping into the bank balance again for the benefit of the RR Very Happy
Post #567684 22nd Sep 2020 8:40am
DrRob
Parallel thread at moment:
https://www.fullfatrr.com/forum/post567683.html#567683 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567689 22nd Sep 2020 9:20am
