![]() | Home > Technical (L322) > Whilst i was in there! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Ebay blanking kit for the Td6. Job done. Loads have done it. Unfortunately my 4.4 TDV8 is not blank compatible |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I got a kit to remove it when I had a TD6. Never caused any issues doing so.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
best Β£30 i spent....engine ran smoother and a slight increase in mpg.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
Plus oil stays cleaner longer. G reg 2.5VM Vogue Portofino red 1991- 1999
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
bought a blanking kit when I had one, the valves are some state when you take them off. Dead easy to do too. I managed it without setting it on fire.. |
Greyskull Member Since: 13 Jun 2019 Location: Selby North Yorkshire Posts: 49 ![]() ![]() ![]() |
Did mine on my tdv8 it looks complicated but once you start itβs pretty straight forward but well worth it and no lights on dash ππ |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 106 ![]() ![]() ![]() |
Thanks for the replies, looks pretty obvious which option so as per normal I'm dipping into the bank balance again for the benefit of the RR |
Parallel thread at moment:
