Home > My Range Rover > New purchase 2011 autobiography
Page 2 of 4 <1234>
Bow down Bow down Bow down Welcome sir... Love the work Bow down Bow down Bow down
Post #568471 1st Oct 2020 12:52am
t5pete
Today's job was to change the gear box oil and filter along with both diff oils and transfers box oil.
The gear box oil was dirty but wasn't burnt and still had a tint of green.
Been out for a run and to be honnest there isn't any difference but all was smooth and fine before.
3.7 ltrs came out and following procedure I managed to get 3.2ltrs back in so unsure if it was over filled to start with.
Il give it 2k miles and will change again to give it chance to circulate and get more fresh oil in.
The front diff oil
Transfer oil
Rear diff oil this was much cleaner than the front so don't know if its all ready had a change at some point.
Post #568791 3rd Oct 2020 3:38pm
Classic Matt
How bad of a job did you find replacing the oil cooler gaskets?
I am due to pick up an L322 which I suspect needs this doing so I'm trying to prepare myself!
Thank you,
Matt.
Post #568888 4th Oct 2020 3:21pm
t5pete
Fairly straightforward job as been mentioned in the wiki the top coolant hose there's a 4 way coupler best to remove it out-of the way before removing the main intake hose to the throttle body
Post #568893 4th Oct 2020 3:42pm
Be very careful that you don’t drop anything into the oilways or let the oil and the water mix....
A few anecdotal stories about some folks destroying the engine by getting water into the oil etc. There is nothing that can't be fixed with a hammer😜😜
Post #568895 4th Oct 2020 3:49pm
Classic Matt
A scary thought! I shall tie the job in with an oil change afterwards to minimise the chance of any issues.
Post #568898 4th Oct 2020 4:28pm
t5pete
Today was rear arches and sills.
Since buying the car I wanted to check the sills and inner arches as they seem prone to rot.
Luckily I've caught it just in time looking at it there's no wonder they rot so bad there is the foam block at the back of the sill where it meets the arch this holds so much water and muck.
First off stripped all the plastic arches and sills then shot blasted to reveal clean metal and thankfully not rot damage.
All metal work was prepped with red oxide then black stone chip and the painted arch lips with etch primer black and clear coat.
I also wax oiled all the inner sills and arches.
One thing to note is the two drains for the sills were all blocked with muck.
For people with the later l322s ide say this is a must if you don't want any future problems.
Also fitted my new steps but forgot to take pictures
Post #570850 24th Oct 2020 9:37pm
DrRob
Cover arch lips with grease then fit Freelander 2 rubber arch protectors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570853 24th Oct 2020 10:14pm
t5pete
Will do Rob cheers, I've all ready wax oiled the lips but once that's dried a little more I'll get some grease on and will order a set of free lander 2 lip protectors now.
Post #570854 24th Oct 2020 10:20pm
t5pete
Is it these ones Rob
Genuine
https://www.ebay.co.uk/itm/GENUINE-LANDROV...SwgQ9Vwexk
Aftermarket
https://www.ebay.co.uk/itm/LAND-ROVER-FREE...SwZcxdnygH
Post #570855 24th Oct 2020 10:23pm
DrRob
https://www.ebay.co.uk/itm/303631687693
Worth reading all pages on this:
https://www.fullfatrr.com/forum/post539650.html#539650 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570861 25th Oct 2020 9:10am
t5pete
Thank you Rob just ordered
Post #570895 25th Oct 2020 4:07pm
DrRob
Trim to fit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570898 25th Oct 2020 4:43pm
t5pete
Picked the wheels up after refurbishment looking forward to getting them fitted
Post #583767 15th Feb 2021 12:28am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Pete, can you let me know where you got the silicone hose from?
Love the post by the way Thumbs Up
Post #583816 15th Feb 2021 1:20pm
Page 2 of 4 <1234>
