Home > My Range Rover > New Car For Nearly New Member
Classic Matt
I have two - Elliott Engineering and Gumtree 4x4.
Funnily enough I actually spoke to Gumtree 4x4 and booked the car in for a once over. It would be nice to know exactly where I stand having had a professional eye cast over it and be able to prioritise anything that does need to be done. Worth it for peace of mind alone!
Matt.
Post #569717 13th Oct 2020 4:26pm
DrRob
I know John at Gumtree. Top outfit. They did a load of welding on my Classic a while back..
It’s in safe hands there Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569733 13th Oct 2020 7:11pm
Classic Matt
Thank you. It has gone to Gumtree sooner than anticipated as I hadn't checked the oil since I collected the car a couple of days ago because I kept parking on slopes (my driveway for example). The first flat surface I parked on was my parking space at work today and... it was overfilled.
My extractor hasn't arrived yet and as I pass Gumtree going to/from work I popped it in but it was the end of the day so they will remove some oil tomorrow.
So tonight I have a Mk1 Freelander TD4 HSE automatic. Not a bad little car to be fair!
Matt.
Post #569742 13th Oct 2020 8:08pm
Classic Matt
PS the above has not allayed the paranoia...
Post #569743 13th Oct 2020 8:09pm
DrRob
It only takes a few millilitres to send it to overfill. Check it when cold and hot.
Somewhere in here
https://www.fullfatrr.com/forum/topic41966.html and
https://www.fullfatrr.com/forum/topic40450...level+cold
The Draper Expert 10L vacuum pump is the dogs danglies Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569747 13th Oct 2020 8:29pm
Classic Matt
Thank you. And yes, the Draper is the one I have gone for.
Matt.
Post #569759 13th Oct 2020 9:43pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Re: New Car For Nearly New Member
Classic Matt wrote:
A nice bit of history is that the first owner appears to have been Jackie Stewart.
Welcome to the club Matt! I'm also a fairly recent owner (2 weeks or so) of a 4.4 TDV8 on a 2010 plate Smile
Very jealous of that first owner, what an amazing person to have owned it!
Post #569896 15th Oct 2020 4:30pm
Classic Matt
Thank you. Is it still easy to find a specialist in Spain?
Post #569916 15th Oct 2020 6:17pm
JAYBOY
Very nice Matt Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #569927 15th Oct 2020 7:49pm
DrRob
Gumtree report? Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569939 15th Oct 2020 9:43pm
Classic Matt
No issues so far - but they have only done an oil change as there was no point taking a bit out when it wanted it changed anyway. They did run the codes too but didn't raise anything in particular. The inspection and the other bits of service are all being done next week.
I did think the ride felt a little jittery and discovered the tyre pressures were all about 10psi too high! I have put them as they should be and it rides far more pleasantly now. I'm starting to recognise a theme of things being over done on this car!
At this point in time I'm thrilled with it, but next week's inspection could alter that...
Post #569941 15th Oct 2020 10:03pm
DrRob
Nice one! Feel free to bomb up to me for a brew and a chat sometime for a chat Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569963 16th Oct 2020 8:45am
Classic Matt
I'm pleased to say the only issue the car will need to return to Gumtree to address is for the rear suspension knuckles to be replaced.
I didn't expect them to need doing as they were replaced just prior to me buying the car but apparently despite them being new parts there is a lot of play in them. Rob at Gumtree was surprised they had failed too but there was no denying the movement in them.
Otherwise nothing of note other than the annoying TPMS fault I already knew about. I thought it had been solved by rotating the spare with another wheel as previously the warning came on 20 minutes into a drive (like clockwork) so after 20 minutes I thought the swap was a success. It lulled me into a false sense of security and took 40 minutes today instead!
Post #570671 22nd Oct 2020 6:05pm
DrRob
Good to hear. Get some decent knuckles put on and not ones made of cheese Whistle
I'm glad I don't have TPMS! Pile of Censored system...use your eyes and toe I was taught Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570733 23rd Oct 2020 2:16pm
Classic Matt
Definitely going for quality knuckles. I just tried to find the invoice for the current ones in the history to see what they were but it doesn't seem to be there which makes me suspect they were the cheapest of the cheap.
For some reason I thought all late L322s would have had TPMS to lucky you not to! I suspect it may end up switched off until I get my next set of tyres and new sensors.
Matt.
Post #570759 23rd Oct 2020 6:30pm
