Home > My Range Rover > Big Blue V8 Story |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 659 |
That's what you call 'cheap motoring' something you don't always associate with Range Rovers! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
26th Oct 2020 9:20am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 922 |
Looking at the parts price list I don't really see where the expense is. Seems like the parts are generally in line with any other manufacturer but its the labour. One garage said they wanted £400 labour to do the rads. Took me 4 hours including bleeding the rad and getting it regassed but that wasnt really working all the time |
26th Oct 2020 9:43am |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Nice one!
28th Oct 2020 10:05am |
So little update. Done both radiators on the range and guess who didn't put the fan shroud back in the correct place and chewed the bottom hose pipe up. Yep that would be me so done a temp repair on that as it's basically leaking out a pin hole so but of mastic and electric tape jobs a goodun
5th Nov 2020 7:28pm |
New modification today to the v8. Had a split in one of the pipes from the expansion tank so sorted that out. Ordered some led bulbs for the reverse lights and low and behold the screw brackets are so brittle it just falls apart so ordered them. Just need to do a minor repair to the indicator next once I've changed the side lights so something more white rather then the candle yellow look
15th Nov 2020 11:52am |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 586 |
looking good did thay do a good job on the wheel arch ? |
15th Nov 2020 12:09pm |
Cheers mate.
15th Nov 2020 12:46pm |
Close one with the belt!!! Tried doing it the other day but couldn't get the fan nut to break. Ordered the locking tool and jobs a goodun. All changed in an hour. |
17th Nov 2020 6:43pm |
17th Nov 2020 6:44pm |
Sooooo next part of the story. Just had a massive box turn up which come from Slovakia. I've just finished work from looking after the public of London so I'm gonna get some sleep for a few hours then I'll fit the parts later on.....
29th Nov 2020 8:43am |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Mate - I am enjoying your updates and great to see an old Rangie getting some love. It looks like you are going to be busy with those big boxes!
29th Nov 2020 9:20pm |
Cheers Mark. It's nice to see people read up on others stories and thank you for your comments. It's much appreciated
30th Nov 2020 8:42am |
Earning its keep today with some towing duties. Might have forgot that trailer was on the back at one point
4th Dec 2020 1:06am |
So finally changed the plugs and oil on the range today. Took longer then normal as I'm recovering from a bad case of covid but pretty simple too do what should I discover. Oh yea all 8 spark plugs all loaded up with oil so ordered a new rocker cover gasket set so that will be the next job this week.
4th Jan 2021 1:06am |
