|  | Home > Technical (L322) > 2003 power steering |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804      | It could possibly be the servotronic valve on the rack is playing up, or may need a refresh of the power steering fluid, or a new pump.
|  18th Nov 2020 9:57pm |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929      | Cheers mate. Soon as your moving it becomes pretty heavy even at 5mph so I'll give that servotronic valve a try. These easy to change or best left too a garage? | ||
|  19th Nov 2020 4:55am |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714      | Try putting a separate 12v feed to the servotronic valve after disconnecting the normal loom connector (its best done with another connector as the pins are too fine to resist any misalignment).
|  19th Nov 2020 9:25am |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929      | Bcm was changed a few months ago now. Had the same problem before it being changed | ||
|  19th Nov 2020 11:14am |
| Posting Rules
