Home > Technical (L322) > door lock
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
door lock
hi
could some one give me or explain to me the door lock system
2005my
last time and the only time i have been game to lock the doors, i could not unlock it
after two days, my son managed to open the doors
haven't locked it since
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #573537 20th Nov 2020 6:32am
knares
i should have mentioned
the fob thing dosnt work
so its only with the key RR 2005 4.4 petrol
Post #573562 20th Nov 2020 12:28pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
So you weren't able to unlock the drivers door using the key blade?
It would suggest a mechanical fault with the door lock if so, as even with the battery disconnected/removed you should be able to unlock the drivers door with the key blade.
Post #573583 20th Nov 2020 3:36pm
knares
thanks
isnt there a code though
which way do you turn the key to lock it, clockwise or anticlockwise
turn the key once, or twice or something
isnt there a lock and a super lock
i seem to remember some one some where saying there was RR 2005 4.4 petrol
Post #573615 21st Nov 2020 12:15am
knares
i think i have worked out the answer to my original question RR 2005 4.4 petrol
Post #574004 25th Nov 2020 4:36am
p38arover
Australia
knares wrote:
thanks
The EKA (Emergency Key Access)? Dunno, I’ve never looked. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #574020 25th Nov 2020 9:22am
knares
code i think is the wrong word, what i meant was what is the sequence
turn the key once, turn the key twice or what ever RR 2005 4.4 petrol
Post #574143 26th Nov 2020 7:10am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Same problem here, broke an emergency key trying to open the door when the battery died an horrible death, any secret code/ password/ holy water required to open the door? Can't turn the key clockwise, body of the key in the way therefore right turn only I would have thought.
Post #574238 26th Nov 2020 9:47pm
knares
sounds like your lock barrel is us
my rover dealer quoted just under $2000 for a new one
having pulled mine to pieces and seeing how it works and goes together if all else fails, i would try and drill out the barrel
or cut the lock with an angle grinder might be better RR 2005 4.4 petrol
Post #574250 27th Nov 2020 1:24am
Red Hot one
I should have looked on Youtube first before even attempting to op the door with the key, using the key to open the door. Only someone with a wild imagination would insert the key, only a little way, twist, lever and remove the cover bit on the handle, then and only then can you use the key, don't forget to disable the alarm by holding the smart key against the steering column, buttons on the outside, then press the stop/start button, why didn't I try to look this up in the owners manual??, Ah locked in the car, silly me. Confused
Post #574343 27th Nov 2020 7:50pm
for your future reference, theres a downloadable owners manual link in the wiki.. ... - .- -.
Post #574345 27th Nov 2020 7:55pm
Red Hot one
Post #574349 27th Nov 2020 8:14pm
p38arover
Australia
Yes, that's the EKA. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #574373 28th Nov 2020 4:26am
knares
took the door latch part out
couldn't find any thing wrong with that
when i went to put it back in, i thought i had bucklys chance of lining up the key part, so i removed it
i found the key part had a broken part
put the lock back together and used a screwdriver instead of the key
with the door open and the latch in the closed position, i turned the screwdriver anticlockwise once
this locked the drivers door
turned it anticlockwise once more and all the doors locked
turned it clockwise once and the drivers door lock unlocked
turned it clockwise a second time, all the windows and sunroof opened and so did the doors
turned it anticlockwise, all the windows and sunroof closed and so did the doors
it changed and changed again
now, when locked, i turn the key clockwise and it opens the drivers door, a second turn, nothing
open the drivers door and the alarm goes off, i then have to put the key in the ignition and turn it on, the alarm stops
i then get out of the car, put the key in the door, turn it clockwise once, nothing, turn it a second time and all the doors open RR 2005 4.4 petrol
Post #574378 28th Nov 2020 6:34am
knares
the broken part on the key assembly, is not available
rover dealer said, just short of $2000 for the replacement parts which have to be bought as a lot, which includes two keys i think
the original part is allie, i made the part out of steel RR 2005 4.4 petrol
Post #574379 28th Nov 2020 6:40am
