|  | Home > Technical (L322) > door lock |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | i should have mentioned
|  20th Nov 2020 11:28am |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 355      | So you weren't able to unlock the drivers door using the key blade?
|  20th Nov 2020 2:36pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | thanks
|  20th Nov 2020 11:15pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | i think i have worked out the answer to my original question RR 2005 4.4 petrol
|  25th Nov 2020 3:36am |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587    |
 The EKA (Emergency Key Access)? Dunno, I’ve never looked. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA | ||
|  25th Nov 2020 8:22am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | code i think is the wrong word, what i meant was what is the sequence
|  26th Nov 2020 6:10am |
| Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 238      | Same problem here, broke an emergency key trying to open the door when the battery died an horrible death, any secret code/ password/ holy water required to open the door? Can't turn the key clockwise, body of the key in the way therefore right turn only I would have thought. | ||
|  26th Nov 2020 8:47pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | sounds like your lock barrel is us
|  27th Nov 2020 12:24am |
| Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 238      | I should have looked on Youtube first before even attempting to op the door with the key, using the key to open the door. Only someone with a wild imagination would insert the key, only a little way, twist, lever and remove the cover bit on the handle, then and only then can you use the key, don't forget to disable the alarm by holding the smart key against the steering column, buttons on the outside, then press the stop/start button, why didn't I try to look this up in the owners manual??, Ah locked in the car, silly me.  | ||
|  27th Nov 2020 6:50pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | for your future reference, theres a downloadable owners manual link in the wiki.. ... - .- -.
|  27th Nov 2020 6:55pm |
|  27th Nov 2020 7:14pm |
 Yes, that's the EKA. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA | ||
|  28th Nov 2020 3:26am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | took the door latch part out
|  28th Nov 2020 5:34am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | the broken part on the key assembly, is not available
|  28th Nov 2020 5:40am |
| Posting Rules
