Home > General > What Did You Do In Your Full Fat Today
Page 324 of 385 <123 ... 323324325 ... 383384385>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I took the RR for a drive around the farm tracks in the village... It was great fun... Trying to find out more about which ones I can use...
I did spend about 30 minutes cleaning the car after... SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #575283 6th Dec 2020 8:27pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Sprained my ankle hiking, meaning I can't ride my Mountain Bike in the forest so... thought I'd go "ride" the trails in the fatty instead!
This may be considered "off roading", but in Catalunya this is what classes as an actual road Rolling with laughter
Post #575558 9th Dec 2020 1:59pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Took mine for an MOT this morning, unfortunately it failed on emissions, that surprised me I must admit.
I was expecting the brake lines to fail as they have had advisories on the last couple of tests.
CO max 0.2 reading 10.41
HC max 200ppm reading 1167ppm
Lamda .97 - 1.03 reading .69 Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #575645 10th Dec 2020 2:16pm
filled mine with diesel, only second time since march.. ... - .- -.
Post #575646 10th Dec 2020 2:24pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Had an MOT, only one advisory, rear axle bushes perished, well pleased with passing, will look at the bushes later.
Post #575732 11th Dec 2020 11:18am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
got new projector puddle lamps to fit Thumbs Up will post a pic later 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575740 11th Dec 2020 1:42pm
ebajema
Cleaned it today, snowfoam etc. Then did the ceramic coating, hoping it will now be easier to clean and stay cleaner for longer.
Put anti-squeal on the brake pads, hoping it cuts the noise down a bit, been getting complaints from the kids!!!
Tomorrow (after surf life saving with the youngest) I plan to pull the compressor out and overhaul it. MY 2010 5.0 SC Galway green and sand interior!!
Post #575812 12th Dec 2020 11:34am
luxmoggy
I can confirm that the car is easier to clean after the Ceramic coating... last week... pressure-wash the large lumps of mud... snow foam... rinse and dry... and it shines... the longest part was the drying it using the Microfibre clothes... SDV8 AB MY 2020
Post #575813 12th Dec 2020 11:46am
supershuttle
Jet washed all the mud off. Geoff
Post #575841 12th Dec 2020 4:53pm
ebajema
Thanks guys, will let you know how it goes.
The anti squeal stuff doesn't work Sad
Did the compressor today, so will let you know in a few weeks time how it does!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #575907 13th Dec 2020 8:18am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Got it open, got it started and went for a lovely drive, reminded me why I bother.
Thanks to those on the forum who helped me out.
Now...how do I fix the door lock so that the key works Whistle
Post #576009 13th Dec 2020 6:38pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Well I picked mine up from the garage. Done the passenger side step but I couldn't do the driver side step. Garage called me up n said they can do it but they would have to weld it to the existing brackets where the old one was cut off. I've managed to stand on the side step n it holds me n I weigh 24 stone so holds a good 155kg with no trouble
Post #576042 13th Dec 2020 11:47pm
JoolsB
Finally fitted the front drop links that I bought in September. What a difference, no rumbles or rattles at all., drives like a Range Rover should.
They are Moog parts so don’t know how good they are, but it’s a fairly easy job so I can always do them again.
Well chuffed
Post #576599 19th Dec 2020 4:36pm
Weegie
Fitted new battery. Went with Varta l1 (020) which was the same as the one I was replacing. Did have to "modify" it slightly. Cool John
GAP iiD BT-Sold
Post #576681 20th Dec 2020 12:33pm
Red Hot one
Took it for a quick spin having changed the gearbox oil and Mechatronic sleeve, nerve wrecking to get the sleeve out and back in again, not quite 5 l oil out, 5.8 l back in, changing gears beautifully and no leaks (so far), will try and get some more oil in when it's cooled down. Cool
Post #576704 20th Dec 2020 4:38pm
