Home > Maintenance & Mods (L405) > Driver door
Kedgers
United Kingdom 2016 Range Rover Vogue SDV8 Santorini Black
Driver door
Hi all
Had situation where driver door would not shut....would literally have to hold it closed when driving round corners.
No amount of pressing the remotes or buttons in the car would sort it.
Now it is just permanently closed shut (whilst everything else opens/closes/locks as it should
Is there anyone else who had this and how was it resolved please?
thanks Rob
Post #577467 28th Dec 2020 12:02pm
Sorry to state the obvious but should have replaced the latch assembly whilst the door was open!
Now you will need to stand there with the remote and keep locking and unlocking until it gives in and unlocks... Do it with the window fully open and try slowly pulling the inner handle whilst unlocking it etc etc... If this fails to work then do a battery reset? Try the handle with the battery off? This may turn off the superlocks? As they are what stops you from opening the door from inside! Worse case, you will need to cut the striker bar off the car! Shocked Yep, it's as bad as it sounds!!!
Post #577514 28th Dec 2020 4:55pm
will the key not unlock it? ... - .- -.
Post #577521 28th Dec 2020 5:05pm
Kedgers
Driver door
Thanks for the helpful replies gents, will give it a go today...including the key !
Post #577606 29th Dec 2020 7:32am
Kedgers
Driver door saga
Hey guys
Got the door open again fairly quickly by just locking/unlocking with fobs but now back to where it wont stay closed.
Even when everything else locks and alarms, the door isnt latched....looks shut but you can pull it open and alarm goes off.
Any suggestions what I should do now please?
Am tempted to disconnect battery and see if that clears it?
thanks Rob
Post #577671 29th Dec 2020 4:27pm
Have you tried lubing the mechanism. There used to be a bung on the 322 to squirt lube into near the lock mechanism. Wonder if it’s worth firing some lithium grease in there to see if it frees it up. There is nothing that can't be fixed with a hammer😜😜
Post #577672 29th Dec 2020 4:38pm
Re: Driver door saga
Kedgers wrote:
Hey guys
thanks Rob
As I said earlier, change the latch mechanism NOW before its locked shut and you cant get it open!
They pack up for a past time!
Post #577730 30th Dec 2020 1:43am
Kedgers
Latch mechanism
Thanks very much
Not got a clue how to get one or how to do that? has anyone got any links please?
thanks Rob
Post #577736 30th Dec 2020 7:57am
It's not a hard job if you have some mechanical skills, but I'm afraid it's far from basic...
Are you competent with vehicle mechanics sir?
Post #577750 30th Dec 2020 12:06pm
Kedgers
Driver door
Hi Cam-Tech-Craig
I cant really say Im proficient though if its a youtube type vid I can follow along and get things done.
I wouldnt know where to buy one of these either.
Maybe I need to get it down to my local independent specialist!?
thanks Rob
Post #577793 30th Dec 2020 5:00pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I had this on my car a few years ago - the passenger door suddenly wouldn't lock/stay closed. I understand that this was a not uncommon problem and was subject to a recall. See https://www.fullfatrr.com/forum/topic34164.html.
Post #577801 30th Dec 2020 6:06pm
Kedgers
Door issue
That’s really interesting thanks , will definitely look into it further & update everyone!
Post #577823 30th Dec 2020 9:19pm
