![]() | Home > Maintenance & Mods (L405) > Driver door |
Sorry to state the obvious but should have replaced the latch assembly whilst the door was open!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
will the key not unlock it? ... - .- -.
Kedgers Member Since: 22 Oct 2020 Location: Kings Langley Posts: 21 ![]() ![]() ![]() |
Thanks for the helpful replies gents, will give it a go today...including the key ! |
Hey guys
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Have you tried lubing the mechanism. There used to be a bung on the 322 to squirt lube into near the lock mechanism. Wonder if it’s worth firing some lithium grease in there to see if it frees it up. There is nothing that can't be fixed with a hammer😜😜
As I said earlier, change the latch mechanism NOW before its locked shut and you cant get it open! They pack up for a past time! |
Thanks very much
It's not a hard job if you have some mechanical skills, but I'm afraid it's far from basic...
Hi Cam-Tech-Craig
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
I had this on my car a few years ago - the passenger door suddenly wouldn't lock/stay closed. I understand that this was a not uncommon problem and was subject to a recall. See https://www.fullfatrr.com/forum/topic34164.html. |
That’s really interesting thanks , will definitely look into it further & update everyone! |
