![]() | Home > Maintenance & Mods (L322) > 4.2 Supercharged Spark Plugs |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1421
Laser Iridium Spark Plug
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
That’s great, thank you! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2300
I did mine yesterday so I can confirm - I got mine from duckworths ended up being the same as euro but delivered... if you are punching over 120k I’d do your coils too... I had a little lumpy idle when cold and this cured all that... if everything is ok then maybe leave for now Current stable:
Thanks for the heads up.
I’ve just ordered 8 of these:
Is it missing on both fuels? |
Yep. Missing on Petrol and LPG.
Good luck, hopefully it's just a bad plug or coil |
Fingers crossed... I’m never that lucky though so am figuring I’m going to end up having to strip it and take the heads off it.
Is it 7 or 8 the miss is on by any chance, and is the valve saver pumped to each cylinder or dripped after the throttle butterfly.
I’m not sure what cylinder the miss is on.
Does it log a fault you can check with iidtool? Mine on petrol and gas got a cylinder 5 fault intermittently but this began before I had the lpg fitted. Changed the plug and the coil problem solved it also has always had a bit of a dirty idle on startup despot (now) not having any vacuum or boost leaks and having new o2 / mafs . So I spent all my pennies on 7 more coils and plug and she seems good now - hopefully you will get lucky. I think I have five of the coils let if you want them for troubleshooting she drove fine in petrol and gas on them Current stable:
Thanks for the offer.
I also have a brand new pre cat denso o2 sensor somewhere you can have cheap if needed Current stable:
| All times are GMT |
