Home > Maintenance & Mods (L322) > 4.2 Supercharged Spark Plugs
dhallworth
I don't have the owners manual to hand for my car, unfortunately, it's at my folks, along with the car.
Does anybody know what spark plugs go in a 2007 Supercharged L322.
Post #577547 28th Dec 2020 7:04pm
dingg1
Laser Iridium Spark Plug
Part
IFR5N10
Ngk
Post #577549 28th Dec 2020 7:13pm
dhallworth
That’s great, thank you! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #577560 28th Dec 2020 9:36pm
Danwilderspin
I did mine yesterday so I can confirm - I got mine from duckworths ended up being the same as euro but delivered... if you are punching over 120k I’d do your coils too... I had a little lumpy idle when cold and this cured all that... if everything is ok then maybe leave for now Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577564 28th Dec 2020 9:50pm
dhallworth
Thanks for the heads up.
I’ve bought a car that’s got a misfire on it on one cylinder. Normally I’d be thinking a plug or a coil but the car has LPG fitted to it. It’s got flashlube installed but I’m expecting the worst in that the valve seats will need doing.
I’ve got my IID tool so am going to order a set of plugs as I’ll need these regardless of the fault, I’ll swap the coils around and see if the fault moves, if it doesn’t, I’ll do a compression test, and see where we go from there. I’d not refit old plugs if I’m stripping it down to do the valves so I’ll need these regardless anyway.
The car was cheap enough that I’m happy to be taking a gamble. Just need to wait for it to arrive now. Thanks to Nicola I’m not meant to be travelling south of the border so I’m waiting for it to be delivered.
Post #577566 28th Dec 2020 10:07pm
dhallworth
I’ve just ordered 8 of these:
https://www.opieoils.co.uk/p-63998-ngk-ifr...ntID=79431
With a discount code they were 68 quid delivered.
Post #577570 28th Dec 2020 10:31pm
dingg1
Is it missing on both fuels?
Post #577573 28th Dec 2020 10:41pm
dhallworth
Yep. Missing on Petrol and LPG.
It was diagnosed as a misfire on one cylinder after it was on diagnostics but the specialist it was at wouldn’t touch it due to the LPG. The other garage that saw the car told the owner it was likely going to be valve seat recession and would cost him circa 4 grand which he wasn’t prepared to spend so no further investigation other then the fault codes has been done.
Tbh, I’m taking everything with a pinch of salt and will do my own troubleshooting when it arrives and see where we go from there.
Post #577574 28th Dec 2020 10:45pm
dingg1
Good luck, hopefully it's just a bad plug or coil Thumbs Up
Post #577575 28th Dec 2020 10:47pm
dhallworth
Fingers crossed... I’m never that lucky though so am figuring I’m going to end up having to strip it and take the heads off it.
I’m clearing a space in the workshop, that way at least I’m prepared and if I do get lucky I’ll have a nice free space to park it in!
Post #577576 28th Dec 2020 10:51pm
dingg1
Is it 7 or 8 the miss is on by any chance, and is the valve saver pumped to each cylinder or dripped after the throttle butterfly.
Apparently if just dripped 7 and 8 are more likely to show signs of vsr, do you know how many miles on lpg?
I'm on 45000 now and no issues but have a slip stream of petrol after 2900 rpm
Post #577577 28th Dec 2020 10:52pm
dhallworth
I’m not sure what cylinder the miss is on.
Apparently it’s had LPG on it for 10 years which would mean somewhere between 80 and 90k on LPG. It does have flashlube but I’ve got no idea how it’s plumbed in as I’ve not seen the car in person yet.
Post #577580 28th Dec 2020 11:00pm
Danwilderspin
Does it log a fault you can check with iidtool? Mine on petrol and gas got a cylinder 5 fault intermittently but this began before I had the lpg fitted. Changed the plug and the coil problem solved it also has always had a bit of a dirty idle on startup despot (now) not having any vacuum or boost leaks and having new o2 / mafs . So I spent all my pennies on 7 more coils and plug and she seems good now - hopefully you will get lucky. I think I have five of the coils let if you want them for troubleshooting she drove fine in petrol and gas on them Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577597 29th Dec 2020 12:19am
dhallworth
Thanks for the offer.
Once I’ve got the car home and have had a chance to properly look over it and do some more troubleshooting I’ll make a list of what I need. Will probably drop you a PM at that point.
Post #577600 29th Dec 2020 12:38am
Danwilderspin
I also have a brand new pre cat denso o2 sensor somewhere you can have cheap if needed Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577650 29th Dec 2020 1:25pm
