Home > General (L405) > Stolen...
Page 4 of 5 <12345>
Rrsport2020
Hi,
I’m usually on the RRsport forum,
My sport was recently stolen and it wasn’t via a keyless relay theft as such;
They picked the drivers door lock, opened the door - alarm went off and then they plugged a device (not a laptop) into the obd port and within seconds the alarm stopped, lights came on and engine started.
They also cut the steering lock off with an angle grinder. All this was done in under 2 minutes. And Land Rover tracker went dead within 5 minutes.
I did a little bit of searching online and it’s very easy to find the device I mention and all the tools available and it seems it’s legal to sell them.
The police didn’t care and didn’t even come to collect or view the cctv footage. Insurance company have been very efficient and good but I am no longer able to insure a Range Rover, most companies won’t even quote me now
Therefore simply disabling keyless or using a faraday pouch is not enough protection, I was going to get a ghost fitted but didn’t get round to it and always thought the steering lock was a good deterrent.
I strongly suggest you all get a ghost or other form of security fitted to your cars, it’s a real pain and very costly when they get nicked.
Post #577859 31st Dec 2020 12:11pm
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
Really sorry to hear that, thanks for posting. 2009 TDV8 3.6
Post #577864 31st Dec 2020 1:06pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
With the device that plugs into the obd port to program a new key would mean the steering lock disengages on ignition.
Post #577876 31st Dec 2020 2:40pm
Rrsport2020
I’m talking about a big yellow steering lock with a separate key, like what was used in the 80s and 90s
Post #577885 31st Dec 2020 3:20pm
GGDR
Sorry to hear that...
False OBD port sounds needed too.
Kill switch too Cheers, Greg
Post #577907 31st Dec 2020 6:36pm
ilard
A tiny nod to extra security, but I have an old iPhone 5 plugged into an obscure charging point in the car....if it’s stolen and they do the dirty on the in-car security, I’ll try “find my phone” on iCloud. I might work... L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #577941 1st Jan 2021 12:00am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Rrsport2020 wrote:
Hi,
They picked the drivers door lock, opened the door - alarm went off ............................................ .
Really sorry to hear of your loss, they should be fogged at the very least.
Can I ask what year you RR sport is please? Post 2015 vehicles have a modified KVM fitted (L405) anyway so I assume the L494 would be there same which was suppose to stop the thieves getting the car started via the OBD port, but there are new devices coming out all the time unfortunately.
Post #578018 1st Jan 2021 7:53pm
Rrsport2020
it was a late 2016, it had the newer KVM where you are unable to programme new keys.
From my research the device they used to start the car can be used on any Land Rover including 2020 models. One of the websites I found even had a video demonstrating it on a discovery sport. Its disgusting!
Post #578028 1st Jan 2021 9:15pm
diesel Dave
Thanks for the response, just ordered one of these, a false OBD port that is live but wont pass data, will fit ASAP and report back on how easy ETC.
Land Rover Dummy OBD 2 Security Port Anti Theft Range Rover Discovery Defender. £12.99 off eBay
Post #578035 1st Jan 2021 9:59pm
nice find Dave..
here's the ebay link,
https://www.ebay.co.uk/itm/Land-Rover-Dumm...SwIsZfa6cx ... - .- -.
Post #578038 1st Jan 2021 10:23pm
Crasher242
Thanks for posting the link - nice find.
One on order now Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #578850 7th Jan 2021 3:41pm
diesel Dave
New OBD dummy port arrived today, really simple to fit.
Just above the peddles there is a removable panel, three 7 mm self tapping bolts. Remove and the panel pulls away.
The OBD port is just to the right of the accelerator pedal, it simply pushes out of it’s bracket using a small screwdriver to assist the clips either in end.
Once out you plug your OBD into the dummy, the end with only two wires, then click the other end back into the slot on your car, job done. I connected my diagnostic tool and it does power it, but that’s all, I was unable to communicate with any of the ECU’s. Hopefully this will fool any would be thief or at least buy some time as the alarm is not disabled once the car is broken into, nor can they start it via the OBD port. Mr. Green
Post #578995 8th Jan 2021 7:33pm
thanks for the info Dave.. Thumbs Up ... - .- -.
Post #578996 8th Jan 2021 7:36pm
Phil.
I’ve bought one too. I assume it will need disconnecting prior to a service? MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #579071 9th Jan 2021 2:01pm
diesel Dave
Hi Phil. Yes that’s the only down side, it will have to be put back to original spec before carrying out any work via the OBD port including service resets, but not too big a job to change it back Thumbs Up
Post #579095 9th Jan 2021 5:49pm
Page 4 of 5 <12345>
